vacuum line diagram
Old September 18th, 2008, 05:09 AM
cutlass cool's Avatar
vacuum line diagram
I gone and done it, screwed up the vacuum line routing, can antone point me to a vacuum line diagram fron a 69 cutlass, 350, a/c auto trans.
cutlass cool is offline
Old September 20th, 2008, 08:03 PM
hamm36's Avatar
Did you get it fixed? Let me know and i will look, and or take photos of a 70 350 with a/c. And try to help.
I would like to know where the carb. side of the vacuum/carbine can goes on a Holley with Edelbrock intakeon a BBO? I ran it to the back of the intake with two vacuum lead on the connector. It seems to be working OK, it is getting plenty of gas. But is it right? Let me know if I can help with the 350.
hamm36 is offline
Old September 21st, 2008, 12:17 AM
Junior Member
88 coupe's Avatar
Originally Posted by hamm36
........ I would like to know where the carb. side of the vacuum/carbine can goes on a Holley ........
https://classicoldsmobile.com/forums/39539-post66.html
Norm
88 coupe is offline
Old September 21st, 2008, 07:07 AM
hamm36's Avatar
Norm, That is a great photo, but that is were the vacuum advance goes right?
My question was. Where does the hose from Carb side of canister assembly on front passenger side go on a Holley/Edalbrock set up? Book shows lower front of stock Carb. I put the hose at the same location as the air cleaner on the back of Edalbrock intake.
hamm36 is offline
Old September 21st, 2008, 09:18 AM
Junior Member
88 coupe's Avatar
........ but that is were the vacuum advance goes right? ........
It is.
........ My question was. Where does the hose from Carb ........
I have no idea.
Maybe, I should start reading posts, before I reply to them.
Norm
88 coupe is offline
Old September 21st, 2008, 06:09 PM
citcapp's Avatar
Look down from the arrow on 88's picture and you will see were the pvc valve is connected. Right next to it is the port were the cannister line goes. Thanks to Norm I found that out after he helped me
citcapp is offline
Old September 25th, 2008, 07:12 PM
hamm36's Avatar
vac can
The 750 duel line single pump I have has the only the PVC connection coming out the back of the throttle plate and nothing else. I am glad you got yours working, and I mine will be fine with the vac can going to the intake. Really seems to be running good.
hamm36 is offline
Old October 8th, 2008, 10:22 AM
chivo80026's Avatar
does anyone know where the 2 thermal vacuum sensor hoses go to on a 231 v6 engine from an 1984 Cutlass???
chivo80026 is offline
Iggyg00
June 21st, 2013 03:15 PM
BStone
September 7th, 2011 09:49 AM
68ragtop
June 29th, 2008 06:43 AM
Giveuptheghost
December 23rd, 2007 06:28 PM
SX455
July 25th, 2007 05:03 PM
Quick Reply: vacuum line diagram
