What is the max rear rim and tire size for a 72 Cutlass
Old March 14th, 2009, 05:28 AM
BigAl72's Avatar
Hello,
I just picked up a street/strip 72 Cutlass. Would like to know if I can fit a 15" by 10 wide rim on the back and what back spacing is best to do it. Also what size tire would work best that rim size? Thanks Al
BigAl72 is offline
Old March 14th, 2009, 07:20 AM
2blu442's Avatar
Wheel Width
Al, welcome to the site. If you would do a search you should come up with several threads where this has been discussed in the past. My personal experience was with a set of 15X10 wheels I had made with zero offset. 295/50/15's looked really nice, but would rub the inside sidewalls when I drove into driveways or anything that made the body roll significantly. I think 275's would work without rubbing, I know 255's won't rub. My 2 cents worth! John
2blu442 is online now
Old March 14th, 2009, 07:30 AM
Past Administrator
Oldsguy's Avatar
Al, welcome to our site.
Oldsguy is offline
Old March 14th, 2009, 01:47 PM
BigAl72's Avatar
Thanks for the welcome
Gents,
Thanks for the welcome. I did do a search but did not come up with much. I know that this topic has had to have been discussed before. The info that I have now is that I get a 15 by 10 with 5.5 BS to fit. It has been suggested that a 325/50/15 was used and fit. It seemed a little large to me. Al
BigAl72 is offline
Old March 14th, 2009, 02:02 PM
2blu442's Avatar
Hello Al
If you only went straight down the track it may work. My measurements showed 14" from the wheewell lip to the inside of the inner fenderwell. The 295 has a 12" footprint so that gives one inch on each side with the backspacing centered. The problem is when the body rolls that space changes. For a daily driver you might get away with a 275 but I don't think anything larger than that will work without rubbing on one side or the other.
If you could come up with a tire and rim you could try bolting it on, then jacking up one side of the rear end to see how much travel you have before the tire hits. John
Old March 14th, 2009, 07:11 PM
car guy
gearheads78's Avatar
10" with 5.5"BS with a 275-60-15 works well from my experience
gearheads78 is offline
Old March 15th, 2009, 07:33 AM
BosMobile's Avatar
i ran 10" with 6/ 4 offset . 275/60/15 .can fit but have to be careful in the turns.a centered wheel should be perfect. i have 8" now,centered ,running 28/10.50/15 mickey thomson slicks they dont rub,and they look killer!! BO
BosMobile is offline
Old March 15th, 2009, 07:20 PM
kaz442's Avatar
I'm running 15x10 with 5.5" BS and a 295/65 15 MT drag radial. I tried a set of 5" BS but the would rub on the outside. This is on my '70 F85.
JKaz
kaz442 is offline
Old March 16th, 2009, 06:16 AM
72greensupreme's Avatar
reply to the biggest tire size qeustion
hi, just wanted to let u know that i have 10.5 inch tires on my 72 supreme and they work well. 295/50r 15 firehawk indy tires with centerline aluminum wheels. lots of meat, and they look awesome. good luck brother. Jay
72greensupreme is offline
L69 equipped
March 19th, 2017 12:31 PM
74_omega
Wheels and Tires
May 27th, 2012 05:09 AM
bigjaythe1st
Wheels and Tires
February 22nd, 2012 01:37 PM
vairtom
August 4th, 2010 07:55 AM
steve19
December 31st, 2008 11:08 AM
Quick Reply: What is the max rear rim and tire size for a 72 Cutlass
