What is proper carb for 1970 Cutlass with 350 4bbl?
Old August 19th, 2010, 07:08 PM
stlbluesbrother's Avatar
Question What is proper carb for 1970 Cutlass with 350 4bbl?
Ok guys - I've thought I had the correct carb on my car, but now I'm thinking the contrary. A long-time Olds mechanic who works on my car noticed an extra bracket on the carb and didn't think it was proper. And now a guy who rebuilds tri-power carbs looked up my carb id in an AC Delco parts book and said my quad was for a full sized car (not a mid-sized car).
So, what is the proper Rochester 4 bbl carburetor for a 1970 Cutlass with 350 cid and automatic transmission?
stlbluesbrother is offline
Old August 19th, 2010, 08:07 PM
Just the facts...
BILL DEMMER's Avatar
7040250
but, others can be made to work properly.
bill
BILL DEMMER is offline
Old August 19th, 2010, 09:47 PM
STOP call'n it a Chevelle
arodenhiser's Avatar
What numbers are on your carb. The tech area at the top of top CO banner has an OE carb listing by year. If you want to replace your carb, other may be interested in it.
Adam
arodenhiser is offline
Old August 20th, 2010, 05:43 AM
Thanks for reminding me of that resource. I've referenced other resources as well (to include the FAQ section of 442.com) and most point to a 7040250. However, how would you read this? 7040250 or 7040255.jpg
The row for 7040250 indicates "Exc. Cutlass". I believe that to mean "except". Therefore, I would think a carb with that id is for a big body car. And the 7040255 would be proper.
So, what is correct?
Old August 20th, 2010, 06:13 PM
Just the facts...
my info comes from the delco number 9 book, it's the bible in that regard.
bill
Old August 20th, 2010, 07:14 PM
svnt442's Avatar
It's a miss-print. 7040250 is what's listed in my chassis servise manual for the non W31 350 4bbl.
svnt442 is offline
Old August 26th, 2010, 03:10 PM
erke88's Avatar
I've been wondering the same thing. I have a 71 cutlass supreme with a 350 4bbl. I ran my carb numbers and it said it was for a 455. I know its original carb.. I thought it was a factory error, but must be a misprint instead lol. Are these carbs sucking 750 cfm?
erke88 is offline
Old August 29th, 2010, 09:30 PM
Just the facts...
they can move up to 750 cfm, the actual amount is determined by the individual engine. the secondary air valves act to "customize" the carb. to the engine's needs.
bill
Old August 31st, 2010, 03:16 PM
BlackGold's Avatar
Just to confirm what others have said:
A 1970 Cutlass with a 4 bbl 350 came from the factory with the 7040250 quadrajet. That's straight from the Engine Assembly Manual, not a service manual.
BlackGold is offline
84oldsDelta88
August 10th, 2013 05:40 PM
oldspackrat
October 10th, 2011 07:09 PM
charlie_hustle
November 24th, 2010 06:08 PM
oldzy
August 10th, 2010 04:49 AM
cutlassss69
March 20th, 2008 07:02 PM
Quick Reply: What is proper carb for 1970 Cutlass with 350 4bbl?
