Lokar throttle cable.
Old March 26th, 2013, 12:25 PM
Fummins's Avatar
Hi Guys, needing a replacement throttle cable about now....wondering if anyone has used a Lokar on their car, and if you did which model #? Mine is a 1969 Cutlass with Edelbrock 4 barrel carb. Thanks.
Fummins is offline
Old May 19th, 2013, 08:31 AM
Daycab's Avatar
Lokar sells universal cables and Summit sells them as packages with the cable bracket included.
I have this project also in the next few weeks as my throttle cable is shot.
Daycab is offline
Old May 19th, 2013, 08:52 AM
Originally Posted by Daycab
Lokar sells universal cables...
"Universal" as in one-size-fits-none unless you have a Chevy? All the Olds vendors sell the correct cable.
joe_padavano is offline
Old May 19th, 2013, 12:20 PM
I got an aftermarket Lokar throttle cable when I installed the Summit carburetor on my 455. It works ok. The bracket doesn't fit snugly on the side of the carburetor. When I let off the throttle the idle steps up sometimes because the bracket gets loose and slips forward. What I need is a bracket that uses two carburetor bolts instead of one. Definitely get the right bracket and cable the first time.
Olds64 is online now
Old May 28th, 2013, 04:45 AM
Oldsmobile enthusiast
s i 442's Avatar
Are you saying they sell the right Lokar cable or the factory cable?
My factory cable used on an aftermarket carb is bent like an "S" because its too long.
s i 442 is offline
Old May 28th, 2013, 06:19 AM
ah64pilot's Avatar
Get the lokar and a Summit (trick flow) bracket...ultimate adjustability and reliability. And they look really nice! I'll post pics when I'm on the computer.
I believe I got the 36" cable IIRC.
ah64pilot is offline
defiant1
February 4th, 2020 08:53 PM
TripDeuces
June 11th, 2011 10:05 AM
RAMBOW
July 2nd, 2010 07:34 PM
rayvera
Ninety-Eight
February 16th, 2007 12:33 PM
rayvera
February 4th, 2007 07:36 AM
Quick Reply: Lokar throttle cable.
