10 bolt lengths
Old July 27th, 2017, 08:17 AM
71DP's Avatar
10 bolt lengths
I am sure this has been discussed many times but I cant seem to find it... What are the outside drum to drum lengths for the 10 bolts? Looking for a 68-72 and cant recall if the 73-77 are longer?
71DP is offline
Old July 27th, 2017, 03:39 PM
Kennybill's Avatar
The control arm mounting brackets are different on the 73/77 housings.
Kennybill is offline
Old July 27th, 2017, 08:33 PM
monzaz's Avatar
lengths
67-72 55.25 housing flange to housing flange or 61" drum to drum
73-77 56.25 housing flange to housing flange or 62" drum to drum
64-66 54.25 housing flange to housing flange or 60" drum to drum
Jim
J D Race
As stated correctly 73-77 are not interchangeable with 64-72 rears...just way different rears and chassis set-up
monzaz is offline
Old July 31st, 2017, 08:33 AM
71DP's Avatar
Ahhh, thank you! Anybody have a pic what the difference in mounting locations are?
71DP is offline
Old July 31st, 2017, 01:42 PM
Rodney
cdrod's Avatar
Vista rear
Are the Vista Cruiser rears wider? I know they use a larger brake shoe than a 2-door model, not sure how that affects the width.
cdrod is offline
Old August 1st, 2017, 02:25 PM
monzaz's Avatar
cruiser differences
No they are the same width - drums are wider inward...backing plates have more backspacing to use 2.5" shoes not the 2" shoes.
The shock mounts are extended, and the frame bump stops are sideways compared to sedan and coupe or convertible rears as the frame rails are probably slightly wider where they would bump the rear end housings if it hit a big enough chuck hole. ...But that is about all the difference.
Obviously axle bearings are different too because wagons carry more weight.
monzaz is offline
2blu442
Tech Editor's Desk
77
February 19th, 2020 01:16 PM
bummerino
October 25th, 2011 08:28 AM
oldzy
June 29th, 2011 10:07 PM
defiant1
January 27th, 2011 06:47 AM
rockethound
Drivetrain/Differentials
November 17th, 2006 03:22 PM
Quick Reply: 10 bolt lengths
