1977 cutlass brougham
Old June 11th, 2010, 06:00 PM
Goofy's Avatar
I am restoring my 77 cutlass brougham from the ground up. I am going to play with the engine, send away to get 400 ponies out of it. Now with that HP do I have to do any thing to the trany or rear end
Goofy is offline
Old June 11th, 2010, 06:51 PM
olds425's Avatar
What trans does it have? If it is anything but a TH400 I would say it needs to be built to handle it. If it was me I would have even the 400 rebuilt to take the higher power. I would probably switch to a 200R4? that is built to take it and gain overdrive also. You will probably have to upgrade or swap the rear also if you plan to take real advantage of the power you are adding .
olds425 is offline
Old June 11th, 2010, 06:57 PM
Goofy's Avatar
trans
Where would you look to find what type of trany it is?
Goofy is offline
Old June 11th, 2010, 07:06 PM
There were no TH400s installed in 1977 Cutlii. Even the 403 was bolted to a TH350.
joe_padavano is online now
texaninla
January 20th, 2014 11:14 PM
TOONLOVESCHERYL
April 7th, 2011 10:38 AM
Goofy
June 11th, 2010 05:57 PM
Ne_stang
September 21st, 2009 12:00 PM
Ne_stang
May 7th, 2009 03:08 AM
Quick Reply: 1977 cutlass brougham
