1977 Olds cutlass 10 bolt gear swap
Hello everybody, im wanting to ditch the 2.73s in my 1977 cutlass. I has a 10 bolt and im pretty sure its a 8.5. its original to the car. my main questions are how do I know its just a 8.5 10 bolt because ive read somewhere that oldsmobiles had some inbred 12 bolt with a 10 bolt cover or something like that. Also whats a good gear for good eighth mile performance with limited street use? speed limit to the track varies between 45-55mph. Its a stock olds 350 with headers,2.5 inch duals, and a quadrajet with some tuning done on it and a th350 stock converter. thanks in advance.
10 bolt 8.5
Ok onto the 1/8 mile deal. You say LIMITED STREET... Meaning not much at all? You will need tire size d you want to use all of the 3 speeds of your trans in full? Your car is NO light weight and you will need some serious gears and slicks to get off the line to give you the best ETs
YOU really need to figure out what you want your car to do for you and where it will spend most of its time.
4.56 4.88 Will be great 1/8" gears BUT very limited for street driving... nasty amount of RPM when driving. YOU NEED A high stall converter to do proper track launches. 2500 at the very least if your cam is stock -
You will need a posi to get both wheel working for you on traction.
Again it is your call how far you want the car to be track bound compared to street bound. Jim
J D RAce
