70 Ralley HELP!!
Second, the automatic driveshafts use two concentric tubes with rubber in between. The manual trans driveshafts are solid.
My car is a Four speed so I would need the solid driveshaft. Is the measurment from transmission yoke to rear end yoke. By yoke I mean the saddle that holds the universal joint. I think OPG had the transmission output yoke.
Frank T Kaluza
Frank T Kaluza
Even though your car is a stick the rubber connected driveshaft will work just fine for a street car and will be much easier to find. Also note that the yoke from a turbo 400 car is too large to fit the turbo 350, Jetaway, or Muncie.
oldtimeclassics
July 27th, 2006 01:15 PM
