Another O-type question
Old December 27th, 2016, 04:09 PM
oldsmobilty's Avatar
I have a 70 O-type with 2:56 gear. I bought the Richmond 3:42 gears and the spacer. Has anyone put one of these together? Is there anything to look out for or be aware of?
oldsmobilty is offline
Old December 28th, 2016, 10:19 AM
Magna86's Avatar
What spacer are you talking about? You cant mount the 3.42 gear on the 2.56 carrier and make it work. Buy a new production posi for it. Jim Monzaz or Brian Trick from here can get you what you need.
Magna86 is offline
Old December 28th, 2016, 10:31 AM
This question is for someone that is familiar with the process. The 3:42 gear will mount to the 2:56 carrier. You can research it on this website. I did buy the spacer and obtained the basic knowledge of this from Brian Trick. Thanks
Old December 28th, 2016, 10:49 AM
https://classicoldsmobile.com/forums...ar-spacer.html
Old December 28th, 2016, 11:26 AM
joesw31's Avatar
Measure all of the shims when you taking it apart, and make sure everything de-burred. And most of all take your time.
joesw31 is offline
Old December 28th, 2016, 01:22 PM
I'm assuming you also have the appropriate bolts for use with the spacer. Other than what has been said about deburring, it's the same as any other ring and pinion installation.
Fun71 is offline
coldwar
February 20th, 2014 01:09 AM
L77F85
Drivetrain/Differentials
16
November 29th, 2013 06:19 AM
2blu442
Body work
February 6th, 2009 04:36 PM
petritl
September 8th, 2008 10:45 AM
olds1968
January 24th, 2008 07:35 AM
Quick Reply: Another O-type question
