Bolt Spacing?
Wow. I should have replied to this sooner. When I bought my 66 olds delta88 about 4 years ago, It came with 15" rims 5x5 wide-lug. In 66, the stock rim was a 14" 5x5 wide-lug with 165-75-r14's (if i can remember correctly.. she's in storage now).
It took me 2 years to locate a set of stock rims. I've looked EVERYWHERE for OEM aftermarket 14"x5x5 lug.. and they DONT EXIST! I found a set of them in an AZ junkyard..
Ed is correct.
The 1966 88 (except the Jetstar 88), 98 and Starfire had 14" wheels with a 5 bolt by 5 inch bolt pattern.
The Jetstar 88 uses the 5 on 4 and 3/4 bot pattern.
I had to replace the wheels on my 98. They are hard to find. Olds used this wheel from 1959 to 1967. In 68 they went to a 15 inch wheel.
The Stickman
January 11th, 2009 05:15 PM
