drive axle snap ring
Old November 7th, 2020, 07:46 AM
lawsrolf's Avatar
Hello anyone out there know where I can find a snap ring for the drive axle that goes inside the differential on the driver's side?
lawsrolf is offline
Old November 7th, 2020, 09:28 AM
I'm guessing you are working on a Toronado, but what year and transmission?
Fun71 is offline
Old November 8th, 2020, 07:36 AM
lawsrolf's Avatar
It's a 79 Toronado with a TH325 Tranny. I spoke with a Summit Racing guy yesterday regarding this situation for about 45 minutes. I think we might have it worked out, however you might have a suggestion and I would welcome it as well. This part that goes into the differential is a flange on the outside and has a spine shaft with a groove on the end of the shaft. This inserts into the differential and the flange on the outside connects to CV Axle with 6 bolts approximately. The Summit Racing guy said that what holds the flange with the shaft inside the differential is a C-Clip which I ordered from Yukon Gear & Axle. What do you think?
lawsrolf is offline
July 8th, 2020 06:54 AM
slade69
Drivetrain/Differentials
January 16th, 2020 03:35 PM
enginenine
October 13th, 2015 05:00 AM
jtdb153
August 12th, 2013 10:28 AM
olds1968
April 18th, 2008 08:39 AM
Quick Reply: drive axle snap ring
