Need help identifying this rear
Old April 12th, 2009, 04:52 PM
gumbyssfakee's Avatar
I got these numbers off of my axel H2B 351. Stamped on the housing I saw the letter "A" and what was either a "N" or "Z". The car is 71 Cutlass 4dr. Any help on identifying this rear in terms of gears and if its correct for this car plus other helpful info would be appreciated.
gumbyssfakee is offline
Old April 14th, 2009, 08:25 AM
monzaz's Avatar
1971 cutlass
Well being a 1971 cutlass...It will most likely be a 8.5 10 bolt rear diff and have bolt in axles with 28 spline axles.
Check the pictures and see if the rear cover looks like the one below ...
monzaz is offline
Old April 14th, 2009, 03:19 PM
I'm fairly confident that it is a 28 spline and know that its a 10 bolt but my real problem is the 8.5 part. A few guys have put the idea in my head that it could possibly be an 8.2 instead of the 8.5. Currently I have an open diff and want a posi so I am trying to figure out what i have. Im hoping the casting # will help.
Old April 15th, 2009, 05:19 AM
Trying to remember member
wmachine's Avatar
The 8.2 would be the earlier "B" and "P" 10-bolt rear from pre-'68.
Does your cover look like what monzaz posted? He's our differential guru, and what he tells you can be taken to the bank.
wmachine is offline
Old April 16th, 2009, 05:18 AM
monzaz's Avatar
rear end ID
Can you post pictures of your diff??? If so we will ID the rear for you.
Does the yoke use u-bolts and nuts to hold the u-joint to the yoke on the rear? OR does it use 2 straps and 4 screw in bolts to hold the u-joint in place?
monzaz is offline
Old April 16th, 2009, 06:11 PM
thanks. ill get some pictures up saturday morning.
Old April 20th, 2009, 08:09 PM
monzaz's Avatar
REAR DIFF PICS
sTILL HERE....LOL. Just kidding take your time. Jim
monzaz is offline
Old April 26th, 2009, 02:53 PM
yea im still here i'm trying to get some time on a lift so i can take a few good clear pictures.
Old April 28th, 2009, 05:13 AM
monzaz's Avatar
reaR
The parts I need to see you will not even need to do that ....But if it makes it easier for you... then will wait. Jim
monzaz is offline
bryndalfly
September 28th, 2016 11:37 AM
mjr
Drivetrain/Differentials
November 15th, 2015 03:30 PM
mr_mahoney
January 31st, 2014 03:53 AM
rocket hot rod
January 9th, 2007 06:21 PM
alan69delta88
July 9th, 2006 05:16 PM
Quick Reply: Need help identifying this rear
