Need A Picture of the Timing Tag on a 70-72 350
Old August 31st, 2011, 10:18 AM
jpc647's Avatar
As the title states, I need a picture of a "clean" or easily readable timing marker. I went to check the timing last night on the car, and I can't read the designations on the damn thing. I don't want to assume they are each a 10 degree increment. I can see all the etched in line, just not the numerical designations. Can't really get in there to clean the thing off, without removing the belts, and fan, even then it's not easy.
Maybe if anyone has found a creative sort of a way to get in there and remove the light corrosion I could try it, but sandpaper and my fingers from underneath the car doesn't seem to work too well.
jpc647 is offline
Old August 31st, 2011, 03:30 PM
BlackGold's Avatar
If no one posts a picture, I believe you will find one in your Chassis Service Manual.
BlackGold is offline
Old August 31st, 2011, 06:16 PM
jpc647's Avatar
Just found one online. In the process of printing it out.
jpc647 is offline
Old September 1st, 2011, 07:39 AM
Run to Rund's Avatar
The steel 350-455 tab has four saw teeth, at 0, 4, 8, 12 deg BTDC. The edge of the tab is 14 deg.
Run to Rund is offline
Old September 1st, 2011, 12:35 PM
jpc647's Avatar
Starting at which side? Driver or passenger?
jpc647 is offline
Old September 1st, 2011, 01:13 PM
Since the engine rotates clockwise looking at the front of it from the radiator, more advance is toward the passenger side, on the top of the damper.
blento
April 26th, 2015 05:59 AM
knoggin
April 17th, 2014 01:48 PM
jpc647
June 10th, 2013 11:48 AM
442scotty
May 13th, 2009 05:42 PM
<miltoncutlas@aol.com>
January 31st, 2004 12:20 AM
Quick Reply: Need A Picture of the Timing Tag on a 70-72 350
