o-type posi
Old May 15th, 2010, 06:08 PM
72hurst's Avatar
o-type posi
I have a 671 posi carrier and was told I could put a clutch pack from a corporate 8.5 posi. Is this true? Also could someone tell me what years the w27 option was available?
72hurst is offline
Old May 15th, 2010, 06:27 PM
svnt442's Avatar
With the O-Axle only 1970 and then it was a special aluminum centered housing that was usually replaced under warranty due to it not being strong enough to hold the abuse put through it.
svnt442 is offline
Old May 18th, 2010, 06:24 AM
507OLDS's Avatar
Yes,the clutch packs from the older style 8.5" 10-bolt posi units are the same.The ones with the "S" spring like what you have.These clutches are a knurled steel,& have square tabs on the ends.The clutches for the Eaton posis will NOT work. GM discontinued the clutches last year,but there are still some sources to get them.
507OLDS is offline
Old May 19th, 2010, 02:32 PM
72hurst's Avatar
o-type posi
Thanks Brian for the confirmation. Could you give me a couple of sources or do you have a set?
72hurst is offline
Old May 19th, 2010, 02:59 PM
507OLDS's Avatar
I bought a bunch from GM when there was word that they were stopping them,but I do not want to sell mine.I've talked with a few people that got them from DTS & a few other differential companies.Ratech also had them under part number RAT-1809,but I do not know if they still have them or not.Have you looked at your clutches yet.You might be able to retain your existing clutches,& just shim them tighter.They weren't assembled very aggressively back then,& usually have room for a bunch more shim.
507OLDS is offline
70vista
April 24th, 2016 06:59 PM
L77F85
Drivetrain/Differentials
16
November 29th, 2013 06:19 AM
jensenracing77
July 11th, 2009 11:02 AM
monzaz
March 17th, 2009 04:05 AM
BIGJOESX
June 3rd, 2008 02:04 PM
Quick Reply: o-type posi
