Pilot Bearing OEM or Bronze Bushing?
Old February 20th, 2014, 01:36 AM
4-Speed's Avatar
65 425 original 4-speed crank- should I go with the original pilot bearing or the bronze bushing?
Thanks-
4-Speed is online now
Old February 20th, 2014, 01:56 PM
citcapp's Avatar
I vote bushing. You will get different opinions on this.
citcapp is offline
Old February 20th, 2014, 01:58 PM
MOTORHEAD
11971four4two's Avatar
bushing is closer to fail safe than the bearing is
11971four4two is online now
Old February 20th, 2014, 02:39 PM
jcdynamic88's Avatar
bushing or bearing
I've seen a bad bearing destroy the input shaft of the trans and then spin in the crank ruining the press fit,never saw a bushing do that.i use the bushing
jcdynamic88 is online now
Old February 20th, 2014, 06:05 PM
Old School Olds
tru-blue 442's Avatar
From my point of view, I had
a 67 C/S with a 330 4-speed
that I did a clutch job on. replaced
all of it. I tossed the bearing and drove
a bushing in place and it was good to go.
Drove well and that rock crusher trans
whined well. I vote bushing.
If you decide you DON'T like it, they
are easily cut out with a nice chisel.
tru-blue 442 is offline
Old April 6th, 2014, 01:04 PM
rocketbob54's Avatar
Thanks-
I went through and researched this very problem about 2 years ago. I was told by many that a bearing is good until it locks up. A steel bushing will eat the pilot shaft as will a "bronze" bushing that has steel content. Always check a bronze bushing with a magnet. If it is attracted don't use it. I found a genuine "old school" sintered bronze pilot bushing at my local Chevy dealership parts counter. I think I asked for one to fit a '72 Chevelle 350 just as an example. The one I got had the correct size center hole but the OD was too large so I turned it down to the correct press fit size on my lathe. Good to go! Hope this helps!
rocketbob54 is offline
Old April 6th, 2014, 02:49 PM
citcapp's Avatar
just a note for an easy way to remove a bronze bushing. find a wooden dowel with an outside diameter nearly the same size as the hole in the bushing. Fill the area behind the bushing and to within a 1/2" of the surface of the bearing. Insert dowel in the hole and the Strike the wooden dowel sharply with a hammer and the bearing will pop out. Old high school auto shop teacher taught me that trick over 50 years ago. Still works
citcapp is offline
Old April 6th, 2014, 03:20 PM
4-Speed's Avatar
Thank-you everyone for your input, appreciate your help, the builder is recommending the bronze bushing also. I still havn't decided yet but leaning this way-
citcapp
48
March 30th, 2014 03:40 AM
4-Speed
February 18th, 2014 04:50 PM
Olds Dad
July 20th, 2011 04:57 PM
ROBZ442
March 2nd, 2011 08:13 AM
4-Speed
July 17th, 2010 08:30 PM
Quick Reply: Pilot Bearing OEM or Bronze Bushing?
