Pulling axle
Pulling axle
Hi folks, it's been a while since I've pulled the axles out of my '71 Supreme. It's just the four bolts behind the hub and no C-clips in the pumpkin, correct? Nothing I have to do inside the pumpkin? I might go ahead and change the oil while I'm at it (MAW!).
I was trying to pull out the remnants of the old axle housing vent tube when the end of the pick broke off and fell inside 🙄 I've tried making tools with a magnet on the end but the vent tube remnant hangs inside too low to make any turns, seems like it's right up against the axle.
I'm hoping I don't need a slide hammer again but my local Harbor Freight has one if needed.
The factory 1971-72 ten bolt "corporate" axles do not use C-clips. Remove the four bolts, flip the brake drum around, thread three lug nuts loosely onto the studs, and use the drum as a slide hammer. Oh, and put a catch pan under the end of the axle before you do this.
Nah, no C-clips the last time I pulled the axles and I'm the second owner of this car so it's mostly original (except for what the current owner has messed up - the current owner being me ). I don't have that enormous hole in the hub, but there are the four bolts. I just couldn't remember if the axle splines are keyed or anything. Will putting it back in be tricky?
@joe_padavano I saw an old reply of yours about using the drum as a slide hammer, i'm totally trying that!
When I had the rear out of the car I changed the 2.73 peg-leg to a limited slip 3.73 a few years back....plus the two years that weren't during the pandemic) so about five years now, I think.
And what, no wise cracks about dropping a piece of metal in that hole?! What, did this become the "nice" forum??
Vent tube should have been plastic. Just leaving the end in would not have done anything to the rear end. - it was only plastic. I have seen rears with axle roller barrel bearings and side shim material and even spider gear and ring and pinion teeth in the axle tubes...No one would have ever known...lol. Jim
JD Race
JD Race
JD Race
JD Race
Just what I was looking for. Thanks Kenneth
Well, it's out. Just have to put it all back together again. Gear oil is still clear yellow (five years old, maybe), and trickling out the plug, so trying to resist that MAW.
dental pick
dental pick
No worries @monzaz , I know you know your stuff. But now you can judge me; after getting everything back together, the plastic remnant fell in! I spent an hour trying to get that sucker out of the hole, and later it just drops in?! Sigh....at my house we call this the "Mac Factor". So back in I went. I realize it wouldn't do the same kind of damage as the metal pick but I figured it would get chewed up into little pieces which would be harder to track down. Besides, I needed the drum brake practice.
Interesting note: I haven't been able to get the self-adjusting brake mechanisms to work, even though it's all together correctly. So this time going in, I assembled the brake on my bench and had a good look. It appears this connector must have stretched out over time and wasn't pulling the mechanism with enough force. So as an experiment I spot welded inside the hook to make it a little tighter. Viola, fixed. A real nice "click" when turning the cog to spread the shoes. I'll do the other three next summer when I replace all the shoes.
drum brake connector thingy, hook welded smaller
Be real careful here. If the self adjuster mechanism is too tight, small irregularities in the drum ID can cause the self-adjuster to tighten up prematurely while you drive, resulting in locked brakes. In half a century of working on these cars, I've never found a "stretched" link. How exactly are you testing this link? The adjuster won't work unless the wheel is in motion while you apply the brake. This rotates the shoes on the backing plate, causing the link to engage. If you are just doing this statically without the drum turning, you are not properly testing the function.
@oldcutlass Rods?
@oldcutlass Rods?
Oh, lol! I think maybe it's called an actuator rod? But I've never seen one in any of the spring kits. Mine are original. And it could be that I was the person that stretched them out. I was pretty green when I first started working on this car. I'll be careful not to make the mechanism too tight. I mean, even after welding-up the hook, it was still easy to put into place. I just can't see any other reason why the plate isn't contacting the star wheel.
On a more frustrating note: I'm replacing the front wheel cylinders (one is leaking) and whoever bent the new brake lines made it near impossible to get to the fitting. Oh yeah, that was me too
