Rear end identification and parts.
Old January 8th, 2022, 01:24 PM
Olds68swede's Avatar
Is this a type o axle?
Is there any diffs and gears available for it?
Could a 3.42 rear be a good setup for a th400?
best regards from sweden.
Olds68swede is offline
Old January 8th, 2022, 02:22 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Yes, that should be the factory Type O 8.5" differential. Only 3.42 and 3.90 gears are available aftermarket and need the 3.08/3.23 carrier to use them. The aftermarket posi are modified 8.8 Ford units. If you are Ok with 3000+ rpm highway cruising, depending on tire height and highway speed limits, you are good to go.
olds 307 and 403 is online now
Old January 8th, 2022, 02:28 PM
Thank you for your answer. Okey, i suppose i cant use the aftermarket gears then since this is a 2.79 carrier, am i correct?
Old January 8th, 2022, 02:45 PM
No, different thickness and I believe 31 spline vs 28 spline axles. A 3.42 is a good ratio, depends what you are comfortable with and where you drive the car. I want overdrive with that gearing, just my preference as everything is a long trip on the Canadian Prairies. Good luck.
Old January 8th, 2022, 02:53 PM
thank you, Will look for another axle then..
If I do find a 3.08 axle will the aftermarket diff fit right in?
Old January 8th, 2022, 03:32 PM
Yes, that is the carrier they chose for whatever reason for the aftermarket modified Ford 8.8 posi in the aftermarket. This only pertains for the 12 bolt cover, 10 bolt ring gear Type O 8.5".
Old January 9th, 2022, 07:52 AM
got it, thanks!
Old January 11th, 2022, 12:14 PM
monzaz's Avatar
Is the rear open or LSD posi? 2.79?
monzaz is online now
Old January 11th, 2022, 12:22 PM
Open, yes 2.79
Old January 11th, 2022, 01:52 PM
14 A 39 = 2.7857
Oldsmobile rounded down and called that a 2.78:1 ratio.
Fun71 is offline
torque406
January 21st, 2022 12:22 PM
tkcutlass
Drivetrain/Differentials
24
March 27th, 2021 07:42 PM
WTHIRTY1
November 26th, 2020 05:42 PM
scottr2200
June 23rd, 2020 09:20 AM
ben442
June 8th, 2019 01:07 PM
Quick Reply: Rear end identification and parts.
