rear end swap
Old June 12th, 2007, 10:46 AM
sscutlas's Avatar
rear end swap
i just purchased a 1986 cutlass, and i wanted to know if a rear from an 80's model camaro will work in this car.
sscutlas is offline
Old June 12th, 2007, 11:12 AM
The suspension design is completely different. The housing won't bolt up.
joe_padavano is online now
Old June 13th, 2007, 07:07 AM
sscutlas's Avatar
thanx for the info
sscutlas is offline
Old September 4th, 2007, 10:20 PM
monzaz's Avatar
rears
Not to mention a totally different size ring and pinion...UNLESS you have a 442 or a GN rear under your car then the guts from that rear will bolt right in. 1970-1980 rears were 10 bolt 8.5 corp rears still used today under 1/2 ton trucks and SUVs. 1990 and newer are 30 spline and the 1999 and newer trucks have bigger carrier bearing now too. BUT all the gears will interchange. Jim
monzaz is offline
350TurBRO
September 12th, 2014 11:52 AM
scrappie
Drivetrain/Differentials
July 25th, 2009 06:55 PM
oldjunk
April 26th, 2009 10:26 PM
olds cutlass
April 9th, 2009 05:44 PM
loosecannon39
February 13th, 2009 03:34 AM
Quick Reply: rear end swap
