Rear fluid capacity?
Old May 15th, 2006, 01:16 PM
Pete77's Avatar
I just bought a 72 Cutlass and until I get my Chilton manual I wanted to start my maintenance on it. How much fluid does it hold? I have the 10 bolt rear with the u shaped notch on each side of the cover. thanks alot
Pete77 is offline
Old July 22nd, 2006, 12:12 AM
monzaz's Avatar
fluid level
Ok every rear is slightly different. usually 2 to 2.5 quarts. The way you check the fluid level is the fill / site plug in the housing passenger side casting.
3/8 socket wrench female square plug... unscrew the plug. fill the car on a level surface( I know it is hard to do with out a lift.) When the fuild starts to dribble out of the sight plug it is full ( gee... that was easy and kind of stupid proof....lol. ) Really that is the way it is done. When it starts to back flow, put that plug back in and you are done. Wipe it clean and have fun. Now you can tip the car slightly up on the passenger side and add a bit extra...NOT alot extra just a little more that will give the axle bearings all they need on turns . More great info can be asked for at wwwjdrace.com GM rearend specialist free registration also. Check it out for more rear diff questions. Thanks, Jim
monzaz is offline
1973olds98
Drivetrain/Differentials
17
September 17th, 2020 11:55 AM
oldjunk
June 17th, 2009 11:55 AM
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
ziff396
April 2nd, 2009 08:01 AM
Pete77
May 15th, 2006 05:37 PM
Quick Reply: Rear fluid capacity?
