rear gears
rear gears
can any body tell me if there is any way i can get gears some where in the range between 370,s and 410,s for my 65 starfire.can i build one out of another rear end? any help on this would be appreciated. thanks will.
Your Starfire should have come with the Pontiac 8.875" rear axle - ten bolt cover, 12 bolt ring gear. The only new aftermarket gears I know of for that axle are the 3.55s sold by Fabcraft.
https://fabcraftmetalworks.com/produ...axlera4-09355/
Yep, We have all been waiting for these gears. Ever since the sale of that copy ...it just has not been good. Nothing last forever... I told them to sell some of the rights to make some of these gears to like a Randy ring and pinion to at least get some equity to build other things they specialize in. ?? I do not know.
I have enough just trying to keep up with the orders here.
Keep checking the junk yards and swap meets and on line forums ...keep posting wants. THAT is a PONTIAC full size car rear so all 65- 70 FULL size car rears and even low powered Oldsmobile full size cars used that rear.
Jim
JD Race
Jim
JD Race
rear gears
hi all, i went to fabcraft, and foundthe master install kit , for 1966 to 76 but it did not go back to 1965 , wondering ,will the 66 kit work on the 65 kit?thanks again. will.
My advice You buy the parts from fabcraft or any internet site, you " might" get the right parts. You will be buying from someone who most likely never even see a differentials inside You buy them from Jim at JD race and Restoration, you will get the right parts You will get phone support if you need it. Jim has built thousands of rears. Jim is a member here, User name Monzaz
You find anything in your area. RUN it by us on the forum or me directly and will make sure it fits your needs. GET PICTURES. If they are not willing to send pics ...Please do not buy it...Too risky these days.
Jim
JD Race
Jim
JD Race
Correct. In the mid-60s, the steepest ratio Olds offered in the full size cars that used the Pontiac 8.875" axle was 3.42. Pontiac, on the other hand, offered ratios up to 4.11 in their full size cars and steeper ratios may have been available over the counter. One trivia item to note is that the Jetstar 88, which used the 8.2" axle derived from the A-body, did offer a 3.55 ratio, at least in 1964-65. Also note that starting in May 1966, Olds installed the 9.3" Typo O axle in many of the full-size cars. Once the Type O was released, the Type P axle was primarily used in the lower HP versions of the B-body (SBOs and 2bbl BBOs). By the 1969 model year, Olds had stopped using the Type P axle.
I know for a fact I had 2 sets of 8.875 FULL SIZE CAR Pontiac 4.33 gears...Found them at swap meets and guys selling them as TRUCK gears...lol.
I would say anything over 4.11 / 4.10 would likely be a speed part from GM counter.
Catalina / 2+2 were raced from Pontiac 65 66 era I guess that was small back in the day...LOL.
rear gears
hey monaz , thank you for the input, and if you ever come across a rear end with 433,s,or anything near that, im your man,right now i have a 323 open rear, i all so have a posi 308, iwill put in my 65 starfire, eventaully, if i don,t find what i want, so any help would be very much appreciated , i think i had a 433 in 1970, i know the starefire i had then was way faster from 0to 60 than the one i have now, ok , i guess thats it , so thanks alot, will.
350TurBRO
September 12th, 2014 11:52 AM
