Timken 712146 seals
Old June 16th, 2023, 11:34 AM
TOM1972's Avatar
Timken 712146 seals
Does anyone know where I can buy the correct all black seals that are "SUPPOSE TO MEASURE .490 at least"
The ones i just received from amazon are the black and gold ones. Thanks
TOM1972 is offline
Old June 16th, 2023, 01:26 PM
Rock Auto shows to have that seal from three different manufacturers.
https://www.rockauto.com/en/partsearch/?partnum=712146
The Timken seal shows to be .470" width.
https://www.rockauto.com/en/moreinfo...118794&jsn=270
Fun71 is online now
Old June 16th, 2023, 02:09 PM
TOM1972's Avatar
thanks for replying Fun71, but according to some of the guys on here, the black and gold ones wont prevent leaking. Not really sure why I cant find the bigger ones online.
TOM1972 is offline
Old June 16th, 2023, 05:27 PM
Get in touch with Monzaz (Jim at JD Race). I think he was the one who alerted us about the seal differences, and he may be able to get you the right seal.
Fun71 is online now
Old June 16th, 2023, 11:29 PM
OLDSter Ralph's Avatar
If I remember correctly, this is concerning the "Set 9" type O differentials. The new seals are only .470 thick. The originals were .495 or so, so they don't seal against the inner differential seal face.
The inner face needs to be more shallow for the .470" seal to work. That would mean welding and re-machining or a possibly a .025-.030" spacer of compatible material that would seal. I PM'ed Jim a while back when this seal problem popped up. The thread died out and I got distracted, so nothing went further.
OLDSter Ralph is offline
Old June 18th, 2023, 09:17 PM
monzaz's Avatar
you can try skf 16735 they say .470 but seem to be pretty good.
If it were me I would really try to find the straight non tapered bearing made from ANY COUNTRY then the seal will not make a difference.
Jim
JD Race
monzaz is offline
Old June 20th, 2023, 10:00 AM
TOM1972's Avatar
Has anyone had luck with the straight rollover ones on ebay? Says they fit. Thanks
Olds Cutlass Supreme 1970-1977 Rear Axle Bearing (OEM Straight Roller Design)
Olds Cutlass Supreme 1970-1977 Rear Axle Bearing (OEM Straight Roller Design) | eBay
TOM1972 is offline
Old June 20th, 2023, 11:14 AM
BillK's Avatar
Just looking in my big National seal book it looks like a 470460 might work and it is .500 thick. The od is a little smaller but should still be a press fit. Might be worth trying ?
What is the actual application ? YMM ? I have some older books I can look through.
BillK is offline
Old June 20th, 2023, 11:32 AM
TOM1972's Avatar
I have a 1972 8.5 olds rear. Been through a few sets of tapered bearings that still leak. Just trying to find a solution and get it back on the road. Thanks for replying.
TOM1972 is offline
oldcutlass
October 24th, 2021 06:22 PM
Troys Toy 70
February 18th, 2019 02:11 PM
sixty9olds
Body work
June 13th, 2009 08:34 PM
KeithA0000
October 28th, 2008 08:23 AM
lzbg17
March 13th, 2008 08:47 AM
Quick Reply: Timken 712146 seals
