TKO driveshaft length a body
Old January 22nd, 2015, 01:20 PM
Seff's Avatar
Check my math - did I miss anything?
Trying to calculate my driveshaft length for my TKO swap.
Currently have a Th350. Length is 27 11/16" = 70.3 cm
Driveshaft with 350 is 55½" = 140.9 cm
My TKO with bell is 77.5 cm end-to-end.
So is my DS really just supposed to be 140,9 - (77.5-70.3) = 133.7 cm?
Thanks.
Bonus question: Stock u-joint for a '71 rear is a GM 3RL u-joint, yes?
Seff is offline
Old January 22nd, 2015, 01:55 PM
garys 68&72's Avatar
Do the actual measurement. There are several sites that show what measurements are required.
Also double check the U joint size.
My reference is a Muncie/T10 and Richmond, but:
In addition, you need to check your yoke length. Make sure it seats in the trans the full length of the output shaft bushing and doesn't bottom out against anything, ie speedo drive gear.
garys 68&72 is offline
Old January 23rd, 2015, 04:52 AM
Seff's Avatar
Fair enough, I'll measure the car.
Seff is offline
Old February 12th, 2015, 05:12 AM
Seff's Avatar
Measured. Lo and behold, 133,6 cm. The drive shaft is being made as we speak, and I'm working on the hydraulic clutch.
Seff is offline
Old February 12th, 2015, 05:29 AM
Any reason you're going hydraulic over the old mechanical linkage?
Old February 12th, 2015, 06:12 AM
Seff's Avatar
I don't have the mechanical linkage, and my frame doesn't have the bracket.
Seff is offline
Old February 13th, 2015, 12:07 AM
Fair enough. I went the mechanical linkage on mine but know several others with hydraulic. And just an fyi, most vendors sell A body kits to convert to manual trans with the Z bar.
Old February 13th, 2015, 12:14 AM
Seff's Avatar
My location limited me somewhat. There was a hydraulic setup for sale over here used on an Skylark which I got at a very reasonable price.
Seff is offline
Old February 13th, 2015, 05:22 AM
Is a generic setup? Hydraulic throwout bearing?
Old February 13th, 2015, 05:51 AM
Seff's Avatar
Well, if the one Ram clutches sells is generic, then yes.
Seff is offline
texasred
Drivetrain/Differentials
April 27th, 2012 07:28 PM
matviar
February 11th, 2012 07:19 AM
texasred
March 14th, 2011 07:42 AM
4-Speed
May 22nd, 2010 06:47 PM
ctrain22
September 8th, 2009 12:15 AM
Quick Reply: TKO driveshaft length a body
