universal joint 1968 442
I wonder if somebody can explain how to get the old u-joints out.
There is no retaining clips on them.It looks like they are glued???
I have put a lot of pressure on the cups but nothing moves.
Should I just use brute force,or are there a better way.
Does new joints with clips fit these yokes.
You still had to pound because the drilling did nothing. The plastic is in a pair of matching grooves in the yoke and the U-joint caps. The little hole you drilled is simply the passageway that the factory used to inject the plastic into the grooves on assembly. Drilling didn't do anything to the plastic in the actual groove that was retaining the caps.
So what's being said is there's no easy way to get the driveshaft off without heat unless you can get a small u joint removal tool in there?
Wait. Are you just removing the driveshaft ? Or replacing universal joints?
Of course you must remove the shaft first to replace u-joints. Have you looked at a manual?
Actually nothing wrong with the originals.
Reviving this one, I got my old u-joints out and have what I assume are the correct new joints for my car(1972 Cutlass S 455/Turbo 400). The new u-joints have internal c-clips that retain them. My question is how do I get these in correctly? The grooves are in different places from stock. Also, do I need to burn out the orange retaining ring? I know this is god awful dumb but I worked as a dealer tech for years, and never actually replaced u-joints, it was usually cheaper to outsource those jobs and get a re-built driveline so this is new to me.
Just get the "X" into position, tap the cups in, and snap on the clips.
It doesn't hurt to chill the cups / heat the yoke a little bit.
If the cup stops "just" before where it needs to be, only like 1/16" away, then take it out again, because you've got a needle lying in the bottom.
The caps go in from the outside of the yoke toward the center.
They slide over the races at the ends of the "X".
The outside surfaces of the caps sit flush with the outside surfaces of the yokes.
The clips fit into the grooves in the edges of the caps near their openings, at the inside of he yokes.
You just snap them on with a screwdriver or whatever (don't let them fly away ).
The clips retain the caps against the inside edges of the yokes, and prevent them from being flung out by (the imaginary) centrifugal force.
I tried to post a picture or what I have but the retaining rings are very thick, unlike the snap rings I am used to seeing. I grasp the concept of what you are saying about the "x" and the caps. My problem is that the retaining rings that came with both sets of u-joints are thick, think thick as the groove in the stock ones, which if installed above the caps would push the caps down.
I have this one:
http://www.oreillyauto.com/site/c/de...7127&ppt=C0362
O'reilly lists the same part number for both ends. You can see the rings I am talking about in the picture, the thickness of the rings is the same as the groove in the u-joint itself.
Am I over thinking this?
I even amaze myself some days. Re-read your post MDchanic and I realized I was having a "special" moment. I got the u-joints in the driveshaft inside of 10 minutes! That should cut down on the vibrations. Now to replace my front pump o-ring.
Wow Eric, I know this is a really old post but so true. How I miss smoking. It gave me just the right amount of time to engage my brain before my hands
You'll know when you have enough heat because the plastic will ooze. If there is no oozing then look for retaining clips as the Ujoints have already been replaced at least once.
They were original U-Joints. I just had to apply the heat to the cap, and not to the area of yoke around the cap. Once I did that the plastic flowed out, and the u-joints pushed out.
Since I had already restored the driveshaft on my car in 2011 (with proper ID stripes) I didn't want to use heat. The shaft still had the original Saginaw u joints and they were in not bad shape. Certainly they weren't dry because I took one cap off to check and then cleaned all the roller bearings and repacked with fresh grease. Fast forward to 2020 - the year that keeps on raining on everyone's parade. I bought some Moog 534G's and took them to my local shop. Dale pressed out the old ones and put the new ones in. Took less than 15 minutes and they were perfect. Unfortunately they charge a flat hour rate to do that, but the shaft didn't get marked up or damaged in the process. Money well spent IMO.
craftsmen22
September 28th, 2011 04:57 PM
