wanted more speed
wanted more speed
i have the 3.23 number 9 rear axle under my 1964-98,and i cant seem to find the specs in the manuals regarding the splines etc.
and now i found on ebay this one,would you guys think it will fitt?
Brand:
GM FACTORY
Product Line:
GENERAL MOTORS RING AND PINION
Ring and Pinion Ratio:
2.56:1
Cover Bolts:
Ring Gear Bolts:
Pinion Spline Count:
27
Carrier Series:
Ring Gear Rotation:
Standard
Ring Gear Teeth:
41
Pinion Gear Teeth:
16
Ring Gear Diameter (in):
8.20
Pinion Shaft Diameter (in):
1.438
Brand:
GM FACTORY
Product Line:
2.56:1
Cover Bolts:
Ring Gear Bolts:
27
Carrier Series:
Ring Gear Rotation:
Standard
Ring Gear Teeth:
41
Pinion Gear Teeth:
16
8.20
1.438
Not even close. The 8.2 axle was used in the 64-up A-body cars. Your 98 uses the 57-64 style axle with the replaceable center section like a Ford 9".
My 64 98 also has the 3.23 rear gears. I think these gears are better than the gears commonly available in later B and C bodies. Combined with a Slim Jim that works correctly this ratio is good for highway cruising and acceleration (for a lead sled).
old 98 rear
You have a 9.3 drop out pontiac / olds rear. They called these the old gasser rears. They used them in narrowed rears for heavy duty drag racing.
3.23 is a very good ratio and highly sought after I would say.
your axle spline count should be 31 and the pinion yoke spline count will be 13
the pig (drop out center) will be held on with 10 studs and 10 nuts.
ring gear will have 12 bolts with 3/8" bolts having right hand thread 24 thread per inch count.
Ring gear diiameter is 9.3 and the pinion shaft diameter is 1.875 where the inner bearing presses on.
The u-joint is held in with 2 u-bolts and 4 lock washers and nuts.
Hope this info help you find what you need. Jim
rearend
I have a 3.08 center here....Some guy gave me 50.00 down and was going to pay the other 200.00 when he was going to pick-up BUT it has been 2 months???? Clueless about what happened to him? Jim
boese1978
January 22nd, 2012 02:34 PM
davesdelta
April 7th, 2009 03:20 PM
