will a rearend from a 73 grand prix fit my 72 cutlass?
Old March 31st, 2008, 10:58 AM
72Cutlass's Avatar
as title states...
thx
72Cutlass is offline
Old April 1st, 2008, 02:54 PM
same but different
don71's Avatar
Probably not, I don't want to steer you wrong. What you want for sure is a 68-72 rear.
The 73-77 is different animal.
don71 is offline
Old April 2nd, 2008, 06:51 PM
DennisG.'s Avatar
No. The upper control arm ears and spring perches are in a different location then the 72 and older.
DennisG. is offline
Old April 18th, 2008, 09:24 AM
monzaz's Avatar
rears
even the shock mount are in different locations too. 73-77 are in the front
1964-1972 are in the rear
spring perches are slightly different too.
width is different
upper control arm mounts are different (already stated)
BUT the guts are interchangeable if that helps... you can remove the 8.5 guts and install them into your8.5 71 72 housing. Try that. Jim
monzaz is offline
djcrook73
January 30th, 2012 07:08 PM
tnelson
September 9th, 2010 05:57 AM
19684424speedconvertible
August 21st, 2009 07:30 PM
Quick Reply: will a rearend from a 73 grand prix fit my 72 cutlass?
