1954 2 Barrel to 4 ...
Old January 23rd, 2024, 09:32 AM
54Rocket's Avatar
  • Getting ready to rebuild original 54 motor due to stuck #3 pistion
  • ...everything (else) in very good original condition
  • but...thinking of going from 2 Barrel carb to 4 Barrel
  • and....evidently need a 4 Barrel intake ... & carb
  • that are specific for 1954...
  • 1) is that true?
  • and 2) where do you find a 54 4 Barell intake?
  • or...is going to a 4 barrel NOT worth the effort?
54Rocket is offline
Old January 23rd, 2024, 10:02 AM
Generally, I'd say upgrading to a 4 barrel carburetor would be an excellent performance enhancement. The only caveat is that you want to make sure you have the proper throttle valve linkage on the side of the carburetor going to the transmission. This is MANDATORY, meaning you won't be able to buy a Holley carburetor from Summit and install it. You'll have to find an intake manifold, carburetor and throttle valve from a 4 barrel parts car. Good luck. 👍
Olds64 is offline
Old January 23rd, 2024, 03:21 PM
2blu442's Avatar
I've got an original carb, but not the intake. I'm located in Oregon. Let me know if you'd like to see pictures of it and if you're interested send me your zip code so I could get shipping costs for a total price to your door.
2blu442 is online now
Old January 23rd, 2024, 03:36 PM
Proud Viet Nam Veteran
redoldsman's Avatar
The 54 and 55 manifolds will interchange and I expect the 56 will too. If John does not have a batwing air cleaner, I have one. Just let me know.
redoldsman is offline
Old January 25th, 2024, 05:41 AM
54Rocket's Avatar
Redoldsman: i thought i heard 54 manifold was specific for that year...and maybe a problem with 56...
so i'll look for a 55
2Blu442: zip is 22664/Woodstock VA....and send some pics...now ...search'n for a 54/55 manifold
54Rocket is offline
Old January 25th, 2024, 07:01 AM
redoldsman's Avatar
I am pretty sure the 54 and 55 interchange. The 56 could have some differences. Charlie Jones is the resident expert on the first generation V-8's (and lots of other stuff). Certainly it is possible I could be completely wrong. Be sure before you pay to ship one of these heavy rascals across the country.
Old January 25th, 2024, 08:18 AM
madmax442.com
madmax442.com's Avatar
I have been in decode casting number mode for 2 weeks now! So yes, wait for Charlie or Tedd to chime in, but I think a '56 will fit, but the casting # is different, maybe from the hot air choke tube or something. '54 & '55 are interchangeable for sure.
Just found this about '56 from Charlie, exhaust crossover https://classicoldsmobile.com/forums...-324-a-163319/
madmax442.com is offline
Old January 25th, 2024, 08:23 AM
Phantom Phixer
Charlie Jones's Avatar
54 & 55 intakes are the same
56 was different. Larger ports.
Charlie Jones is offline
Old January 25th, 2024, 09:38 AM
54Rocket's Avatar
Luckly ...only thing this car needs is rebuild on engine/trans/front end
look'n for someone around Virgina...since i've already got a 67 Triumph in pieces...
54Rocket is offline
Old January 25th, 2024, 09:48 AM
Beautiful!
Good luck finding the pieces you need.
Olds64 is offline
F85 330 ctls
May 11th, 2022 08:43 AM
F85 330 ctls
September 16th, 2019 04:28 PM
jjokrm
November 19th, 2016 03:22 PM
CUT-N-UP
April 18th, 2011 07:32 AM
66ninetyeightls
September 23rd, 2009 07:27 PM
Quick Reply: 1954 2 Barrel to 4 ...
