1960 Super 88 Engine Options?
i have a 394 in a twodoor coupe and want to convert it to a chevy or other motor for daily cruising i don't want to put the miles on the 394 and right now rebuilding the 394 is tooo $$.
Is it possible to put a cheyv or better yet a later gen Olds such as a 455?
Any feeback will be greatly appreciated
60 olds
It might to late but i just put a olds 350 in my 61 the 455 will use the same motor mounts as a 350 it will sit a littel higher. The problem is the tranny if you go with an th 350 you have to cut the tranny hump out and move it back. or get a adapter kit.
my 2 cents........the 394's bullet proof.......find the money/or lay the car up til you have the money......
if GOD had wanted a 350 chevy or other blk in it............he'd have showed up in lansing ......and installed it himself.........
1960OLDSSUPEREIGHTYEIGHT
August 3rd, 2009 07:14 AM
