1987 olds delta 88
Old May 4th, 2006, 06:08 AM
olds87's Avatar
1987 olds delta 88
Hi all, great site! I have a 187 olds dekta 88. The catylitic converter was making a loud rattling noise inside of it for a little while and i put off changing it cause it quited down but the other day i went to start the car and it would turn over and stop then turn over again. I checked and topped up the oil and it started up but i went vack to start it again later and it just turns over and over with a small backfire coming from the catylitic.It seems to turn over extremely easy now. I am getting spark but after cranking it over i noticed exhaust coming from the open end of the air intake that attached to the maf sensor.This tells me that the cat is probably blocked but will that blockage stop the car from starting and if it is blocked would that have cause something internal to have let go cause like i say it cranks over really easy now.Thanks for any help and sorry if i didnt explain this matter to well.Also does anyone know how old a car has to be to be able to replace the cat with a pipe legally.I live in northern ontario, Canada.
olds87 is offline
Old April 24th, 2007, 01:59 PM
TennesseeDelta's Avatar
I know is post is over a year old, dont know if you even still have the car? I would just cut the cat off and run a straight pipe. I have a 83 delta 88 two door coupe and thats what I did with it runs great. hope that helps
TennesseeDelta is offline
zk194
October 11th, 2013 11:10 PM
WiSeGuY
Brakes/Hydraulic Systems
April 7th, 2009 06:39 PM
llj537
Ninety-Eight
April 16th, 2008 07:42 PM
gm guy
March 17th, 2008 08:31 AM
Michael
July 19th, 2007 12:32 AM
Quick Reply: 1987 olds delta 88
