63 Dynamic 88 inner tie rod ends????
Old June 2nd, 2023, 01:23 PM
Bigbassape's Avatar
Anybody have a line on a source for inner tie rod ends for a 63 Dynamic 88. Napa has a part number but it reads as not available. No luck at Kanter or Fusick either. I've rebuilt or replaced my whole front end from Spindle nut to spindle nut. the only thing I haven't been able to source is these inner tierod ends.
Thanks!
-g
Bigbassape is offline
Old June 2nd, 2023, 06:55 PM
Phantom Phixer
Charlie Jones's Avatar
Search E-Bay frequently.
They will pop up from time to time, that's where I got mine.
Have you tried Craig at Mobileparts?
He has a lot of this type of stuff.
Charlie Jones is online now
Old June 2nd, 2023, 08:09 PM
Thompson or Saginaw? With or without P/S?
Thompson without P/S is 588106 (both sides)
Thompson with P/S is 588106 RH, 588107 LH
Saginaw without P/S is 5678057 (both sides)
Saginaw with P/S is 5678057 RH, 5694576 LH
Search these part numbers and you'll find a few on ebay
joe_padavano is offline
Old June 4th, 2023, 02:36 AM
mpolds's Avatar
And a quick aside….
I should have *** N.O.S. *** U.S.A made *** Inner Tie Rods for both the
T R W / Thompson set up and the Saginaw set up….
Always best to simply call me —- 516 - 485 - 193five —- Craig…..
mpolds is offline
Old June 4th, 2023, 08:26 AM
Bigbassape's Avatar
How do I identify whether my existing setup is Thompson or Saginaw?
thanks for your help!
-g
Old June 4th, 2023, 08:47 AM
-g
Old June 4th, 2023, 02:11 PM
Phantom Phixer
-g
Another quick way to tell Saginaw from Thompson, is to look for a forging number on the bottom of the pitman arm.
The one that is attached to the steering box.
On a '63, it should be 5676457 if it has Saginaw components.
Anything else would be Thompson.
Old June 4th, 2023, 03:20 PM
mpolds's Avatar
And, in addition to the assistance Joe P. and Charlie Jones have provided,
Joe P. Has also provided, in this subsection, the chart which indicates the very best measurement is the smallest taper at the Pitman Arm on the drivers’ side is .556 for the TRW / Thompson versus .587 for the Saginaw….
That little .031 difference is unfortunately, CRITICAL , as the parts just simply do N O T interchange….
One basic inherent problem with these cars’ suspension and steering —- they used the two different systems….
We can only , 60 years later, utter the two words, “ Oh well “ , or repeat the famous phrase, “ It is what it is “ ……
Craig…..
mpolds is offline
Old June 5th, 2023, 06:32 AM
Craig…..
Craig, is that true for the 1963-64 tie rod ends? The taper difference I posted was for the pins on the center link on the 1965-68 cars.
Old June 5th, 2023, 07:24 AM
mpolds's Avatar
Joe P.,
Yes --- Inner Tie Rods on 1963 - 1964 Oldsmobile Full Size are governed by all the same exact factors, so that is that .556 vs .587 , which may be the most definitive way to determine the system utilized on a particular car....
This information, is according to the old Moog and TRW catalogs, which I have seen to be accurate in every instance, so far....
Craig....
And, that other chart you showed those other couple gentlemen, is the very best chart, for 1961 - 1962, 1963 - 1964, and 1965 - 1968.... keep that one handy.....
( I have that same chart, and another version of it, but I am nowhere near as skilled as you are on this new-fangled stuff !! I am simply a typist and a dinosaur !! )
mpolds is offline
Old July 25th, 2023, 09:33 AM
Bigbassape's Avatar
I finally had time to get under it and look around. I see no numbers on the pitman arm. Am i safe in assuming its thompson components?
Old July 25th, 2023, 09:43 AM
mpolds's Avatar
Maybe —- but not 100 %…
Supposedly, the big script “ S “ signifies “ Saginaw “ —- and in a perfect world,
if that 5676457 G M / Saginaw is N O T there, then it probably isn’t Saginaw —- and hence, would be, T R W , Thompson, or Alternate design….( all nomenclature for the “ other “ Steering….
However, we are using words “ supposedly “, “ probably “ and “ should be “ and “ safe in assuming”…..
and, the only way I have found which is Definitive is that magical measurement
of .556 vs. .587…..
Otherwise, you are gambling to some extent, and I have Never met a gambler who won each and every single bet….
Craig…..
mpolds is offline
Old July 25th, 2023, 06:00 PM
Phantom Phixer
I think if you wire brush the bottom of that pitman arm, you will find some numbers.
Numbers on forgings do not stand out as much as they do on castings.
Even a fairly thin layer of dirt will hide them.
Old July 25th, 2023, 06:37 PM
Only if you are 100% sure those are OEM parts and not a replacement sometime in the last sixty years.
Old July 30th, 2023, 02:41 PM
deaddds's Avatar
So do you have power steering or not and did you figure out which you have? I probably have several of each. dead@mchsi.com
deaddds is offline
Old September 2nd, 2023, 05:11 PM
mpolds's Avatar
Hey Bigbassape,
Should we safely " assume " you have abandoned the project.... It was 4 months ago when you started this thread.... And two months since you've been
On this site....
Is the car still in a barn... or has it been ditched or sold as is ???
Just wondering.... Craig....
mpolds is offline
Old January 12th, 2024, 12:01 PM
Bigbassape's Avatar
Originally Posted by mpolds
Hey Bigbassape,
On this site....
Not abandoned. Just on the back burner. Had some fairly significant life events to deal with that took many months of my time and depleted my finances. . Just now starting to dive back into the project. Hoping to get it up in the air and get some details so I can finally order some parts!
12dwilson1992
November 10th, 2021 10:36 AM
Brownie12
Brakes/Hydraulic Systems
September 13th, 2021 12:06 PM
tedrw
August 9th, 2019 09:09 AM
andyolds88
May 24th, 2014 09:45 PM
<1963 Olds Dynamic 88 Conv>
March 20th, 2010 11:26 AM
Quick Reply: 63 Dynamic 88 inner tie rod ends????
