85 delta 88 wipers won't shut off
Old January 27th, 2008, 01:16 PM
d.smith1's Avatar
The wipers on my 85 delta 88 won't shut off unless the ignition switch is 1st turned off. The wipers work fine in all modes otherwise. What the problem?
d.smith1 is offline
Old January 27th, 2008, 06:30 PM
ztim's Avatar
Did you replace the switch already?
ztim is offline
Old January 27th, 2008, 07:08 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Your switch could be going bad.
There could be a grounding in the lead wire from wiper terminal 1 to the wiper switch.
The wiper terminals could just be corroded, and in need of cleaning.
Your circuitboard could be dirty or starting to fail.
Are you holding the wash lever forward for a long period of time?
The circuit board will count the number of seconds that you held the washer lever down, add 6 seconds to it.... and then continue to cycle until it's prescribed time is finished.
So if you were out of fluid and holding the button down trying to squeeze out that last little bit....
J-(Chicago) is offline
Old January 30th, 2008, 12:08 PM
Redog's Avatar
Is the plug tight in the wiper motor.
Had the same problem, but a new plug (junkyard) fixed that right up.
Still have the problem with the "washer" switch, but I don't use that
Redog is offline
twinjracing
Vista Cruiser & Wagons
October 7th, 2014 09:48 AM
Rios69Cutty
October 18th, 2012 04:22 PM
jdharris76
September 10th, 2012 11:50 AM
Wyze
December 20th, 2009 05:57 PM
American Lead
April 20th, 2009 12:47 PM
Quick Reply: 85 delta 88 wipers won't shut off
