Broken gear selector needle
Old September 16th, 2008, 08:46 PM
FATRATMATT's Avatar
As I was leaving tonight's car show I noticed that the gear selector needle in my 68 Delmont 88 wasn't reading in the correct gear. (It said I was in S when in fact I was in drive) When I arrived home and put the car in park the needle broke off completely. How hard is it to repair the selector needle? Do I need to take dash apart or can I take the bottom of the column off to gain access? It was dark when I drove up tonight and didn't want to make the problem worst by fumbling around in the dark. Any suggestions???
Last edited by FATRATMATT; September 16th, 2008 at 08:47 PM. Reason: added car year
FATRATMATT is offline
Old September 16th, 2008, 11:25 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
If It's a column shift, it's just a little cable in the column.
J-(Chicago) is offline
Old September 17th, 2008, 04:11 AM
Oldsdruid
rocketraider's Avatar
I think it was still a hard link instead of a thread back then. You should be able to drop the trim plate under the column and access it. Probably held onto the column by a screw and clamp.
Maybe you'll get lucky and it just fell off!
If it's intact, it can be adjusted for correct indication. Put shifter in drive, then move the pointer until it aligns with D in the dash. Tighten the screw. Move the lever thru all ranges and see if everything lines up.
If it's broke off, junkyard from a 67-68 88 or Ninety Eight. Doubt you'd ever find an NOS one.
rocketraider is offline
Old September 17th, 2008, 06:04 AM
The gear indicator on my 64 98 broke as well. I haven't gotten into the steering column or dash to fix it yet. I have heard it is an easy fix.
Olds64 is offline
Old September 17th, 2008, 06:44 PM
FATRATMATT's Avatar
I bet my luck it broke off. It felt for a second like it was in a bind with something and I thought I heard a cracking sound. Won't be able to look until friday. I'll let you know.
Old October 15th, 2008, 02:59 PM
FATRATMATT's Avatar
It took a little time before I was able to look BUT it did break and it's only a wire which wraps around the column. I know where a 4 door 88 sits in a junk yard. I just have to wait until thanksgiving to go home and get it. Thanks to all who helped solve this small problem with me.
Old October 16th, 2008, 04:21 AM
Danny Wiseley's Avatar
Save the pieces of the broken one for a pattern in case you end up having to make one from scratch.
Danny Wiseley is offline
DeepBlue91
March 13th, 2015 07:14 PM
VI Cutty
October 4th, 2014 12:02 PM
Eli 72
March 30th, 2014 01:16 AM
Redog
July 20th, 2011 03:37 PM
carnell71075
November 21st, 2007 03:26 AM
Quick Reply: Broken gear selector needle
