Front motor mount, 56 Olds
Old December 8th, 2013, 08:07 AM
rket56's Avatar
In putting everything back together, I find the driveshaft is too long. The engine and trans were out and new rear springs installed. Before I pull the new springs and put the old ones back in, I wonder if I put in the front engine mount in correctly. Does the mounting foot face the radiator, the way I have it now, or does it face the rear of the car? Please take a minute and see how yours looks and let me know. Thanks Chuck
rket56 is offline
Old December 9th, 2013, 07:32 AM
Tedd Thompson's Avatar
Sorry I can't get to my car for a while and check on that front mount orientation but if the front mount was backwards wouldn't the transmission mounts be off also, holes not lining up.Did you have the transmission bolted up first then the front mount?.....Tedd
Tedd Thompson is offline
Old December 9th, 2013, 09:22 AM
rket56's Avatar
Tedd, the engine and trans were put in as a unit. There is more than one set of holes in the frame, and the cross member is not symmetrical, and the mounts them selves can be reversed. I think the way I have it is correct based on the distance between the fan and the radiator, but perhaps the fan could move closer by an inch and still clear. The front mount, to my way of thinking, dictates the engine position. Thanks for your input, Chuck
rket56 is offline
Old December 11th, 2013, 09:05 AM
rket56's Avatar
Found some old pictures of when I first took out the engine and trans. I do have the front mount installed correctly, the problem in the driveshaft length is the rear end. I will have to go out and dig the old springs out of the pile under the deck and put them back in. Will let you know what I find. Thanks, Chuck
rket56 is offline
Old December 12th, 2013, 03:15 AM
Yellowstatue's Avatar
You might have the springs in front to back...
Yellowstatue is offline
Old December 12th, 2013, 10:16 AM
rket56's Avatar
Thanks Yellowstatue: I dug the old springs out of the pile yesterday and noted that the locator was not centered. I went back and looked up my daily journal on the re-assembly and found that apparently I had installed they correctly the first time, but for reasons I don't remember, reversed them. I will heat up the garage this pm and flip those puppies back around. Since the engine/trans was not in at that time, I couldn't use the drive shaft as a gage. Appreciate your help, Chuck
rket56 is offline
Old December 13th, 2013, 03:05 AM
No charge...
rket56
December 18th, 2013 10:05 PM
chemist64
August 25th, 2010 10:23 PM
Zeeman57
September 9th, 2008 08:05 AM
Zeeman57
June 12th, 2007 12:44 PM
mcutlass1969
July 18th, 2006 01:58 PM
Quick Reply: Front motor mount, 56 Olds
