frozen heat riser control valve 394 V8
Old January 13th, 2024, 01:52 PM
davek1661's Avatar
My 1964 Dynamic 88 has a frozen heat riser control valve on the driver side exhaust manifold (of course it's on the driver side manifold since that's where they all are!). Any idea how to free it up? Anyone had to do this? I just finished for the day so I haven't even attempted it, figured I'd toss it out there
davek1661 is offline
Old January 13th, 2024, 03:08 PM
The valve was frozen on the 394 in my 64 98 many years ago. I knocked the valve off of the pivot shaft and left the shaft in the exhaust manifold. It worked fine, probably not an ideal fix though.
Olds64 is offline
Old January 13th, 2024, 03:40 PM
Sugar Bear's Avatar
Is the manifold on or off the car?
Sugar Bear is online now
Old January 13th, 2024, 03:56 PM
OLDSter Ralph's Avatar
Perhaps try soaking it in Evaporust or something like PB Blaster ?
OLDSter Ralph is offline
Old January 13th, 2024, 04:58 PM
davek1661's Avatar
It's off the car. I considered soaking it in "blaster" as has been suggested, or a torch. I can buy NOS from ebay for less than $200
I'll probably try a good soak- that usually makes me feel better
Old January 13th, 2024, 05:25 PM
Sugar Bear's Avatar
Warm the area, then put penetrating oil on it and tap/strike the joint. The penetrant will get wicked into the joint as it cools, striking it will cause vibration...rinse and repeat. These can be very difficult to get moving again.
You could also try putting it in an electrolysis bath.
Old January 13th, 2024, 07:37 PM
Phantom Phixer
Charlie Jones's Avatar
This idea might work if the vehicle is not operated in weather below 50 degrees. Such as a summer only hobby car.
Charlie Jones is online now
Old January 13th, 2024, 07:53 PM
As long as I remember, myself and most everyone else I've known basically welded them open or removed them and filled the holes. It will not cause any issues in the operation of the engine in any temp. It's common for them to get stuck in both the open and closed position.
oldcutlass is online now
Old January 14th, 2024, 07:10 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
What Eric said. Remove it and weld the shaft holes closed.
droldsmorland is offline
Old January 14th, 2024, 01:21 PM
davek1661's Avatar
It was stuck mostly closed. Using Sugar Bear's suggestion I got it open. I can move it with a hammer by striking it, but no way it's going to work as designed. It's open now, and I'm going to leave it like that.
Old January 14th, 2024, 01:28 PM
Sugar Bear's Avatar
If it is regularly juiced with penetrating oil when the engine is warm and allowed to cool it may start to work again. Take note of the current external weight position and check it occasionally to confirm that it hasn't begun to move and stick closed.
Old January 14th, 2024, 02:15 PM
Wire it open and leave it.
Old January 14th, 2024, 03:49 PM
davek1661's Avatar
I'll just leave the spring loose. It's stuck where I want it. I'm okay with that.
Thanks for all the tips and suggestions, everyone. I really appreciate the feedback.
Oldster65
July 1st, 2023 11:05 AM
Boilerz25
May 23rd, 2014 09:00 AM
peteyb
November 9th, 2013 08:55 PM
fbonanno
March 11th, 2013 03:46 AM
bjtstarfire
November 13th, 2008 02:04 PM
Quick Reply: frozen heat riser control valve 394 V8
