Holy gas tank, Batman!
Old July 24th, 2009, 06:22 PM
Registered Lunatic
Crazy88's Avatar
I dropped the tank in my Dynamic, only to find it's rusted through in one spot...pretty big hole. Are replacement tanks available? This car seems to be goofy as the tank is behind the axle, not under the trunk. If no replacements are around, can it be repaired? Also, is there a way to mount a fuel cell in the trunk without fear of fumes?
Crazy88 is offline
Old July 26th, 2009, 12:52 PM
bjtstarfire's Avatar
It might be hard to find a new replacement, but I had my tank repaired at a local shop for 50 bucks and it is holding up fine - last 4years. The repair shop , stated that the tank was in great shape, I knew that prior to lining up the repair...
If your delaing with major rust then do an internet search for shop that can remanufacture/repair your tank - there is a shop in westen PA (Greensburg area) that does this.
Good luck.
bjtstarfire is offline
Old July 26th, 2009, 12:59 PM
Registered Lunatic
Crazy88's Avatar
Thanks...ya, I'm looking in to custom tanks. I think it's too rusted to bother fixing.
Crazy88 is offline
Old July 28th, 2009, 09:05 PM
Registered Lunatic
Crazy88's Avatar
Well, I got a rough estimate from Alumiworx/Boyd Welding. $330 for the sketch I gave him, but I think it will end up closer to $400. So in goes a 12 gal. boat tank til I can do that....
Crazy88 is offline
Old July 29th, 2009, 05:33 AM
csstrux's Avatar
I am not sure but would think a b body tank off another car would work. Maybe check to see if repops are available for the 63/64 impala. Don't have time to check up on this myself right now but others may know if this part is common off the top of their head.
csstrux is offline
Old July 29th, 2009, 05:58 AM
Purveyor of Polyurethane
ijasond's Avatar
I'd be curious to see about an Impala tank as well. I know that a lot of the Impala and/or caprice stuff will fit on my 66 Delta 88. I'm sure you could get the dimensions of the tank and see if it looks like you could make it work.
ijasond is offline
Old July 29th, 2009, 12:26 PM
Registered Lunatic
Crazy88's Avatar
Ya, I checked that out for sure, it seems all the impalas had under-trunk tanks with rear fill that I could find. Mine is located right behind the rear axle, totally different design.
Crazy88 is offline
Old August 6th, 2009, 05:09 PM
csstrux's Avatar
Kinda gathered that would be the case after finding out you have a perimeter frame from another thread. Have you checked around on any Buicks? Apparently they have perimeter frames as well.
csstrux is offline
Old August 6th, 2009, 05:16 PM
Registered Lunatic
Crazy88's Avatar
Hmmm, I shall look in to that, thanks.
Crazy88 is offline
cherokeepeople
July 24th, 2015 05:30 PM
jaunty75
January 20th, 2013 01:48 PM
Ranzan
March 18th, 2010 07:08 AM
freebird72
July 3rd, 2009 11:50 PM
SuperSickBoy
October 3rd, 2006 12:51 PM
Quick Reply: Holy gas tank, Batman!
