Interchange for a 62 Dynamic Turn Signal Cancel Cam
Does anyone know of an interchange from another vehicle that I could get a turn signal cancel cam for a 62 Dynamic or Starfire.
It's kinda hard to tell exactly what you need,but I'll try.
The turn signal is cancelled by the action of a roll pin which is driven into the steering wheel. If this is broken it can be replaced by a common 5/32 x 1-5/8 spring type roll pin. This pin acts on the actuator ,which is the part that the lever screws into.This part is listed as #5644991 and is listed as fitting all 1961 and 1962 models with Hydramatic except F-85.
A check of Chevrolet and Pontiac parts books does not show this number so I think the interchange possibilities are slim.
eddieunderground
February 22nd, 2013 06:56 AM
