Tachometer in your 50's Olds
Old February 27th, 2023, 07:53 PM
madmax442.com
madmax442.com's Avatar
Anyone want to share your tachometer mounting ideas? I am thinking of running a smaller, under 3 inch diameter pedestal mount on the column, really don't want to mess with the look on the beautiful dash, but I have got have a tach to drive it, tune it, etc. So basically, I am torn. Thoughts?
madmax442.com is offline
Old February 28th, 2023, 05:45 PM
madmax442.com
Ok, well here it is. It's pretty small, 2 1/2 inches. I think its gonna grow on me. We'll see.
Old February 28th, 2023, 07:37 PM
Is it a hotrod or a basic stock restored car?
oldcutlass is online now
Old March 1st, 2023, 11:16 AM
madmax442.com
No, its all original. I wired it with a 4 blade connector I can just take it out if purists are hovering at a car show.
Old March 3rd, 2023, 08:28 AM
Tedd Thompson's Avatar
Why do you need a tachometer ?it's an automatic car and i will never be over revved and shifts itself when it's time to shift. I must be a purist then. To me, it looks out of place and just tacked on . To each his own. If you like it that's where it should be...Tedd
Tedd Thompson is offline
Old March 3rd, 2023, 09:46 AM
madmax442.com
its quit on me a few times, hard to even tell if its still running, 400 rpm in drive. Ill pull it out before any purist looks at it! Lol thanks for the input.
Old March 5th, 2023, 10:45 AM
madmax442.com
Ok, column mount is out, just way too gawdy. I moved it under the dash, used the bottom screw for the ash tray, so no holes drilled.
Old September 13th, 2023, 08:21 AM
WikedOldsmoileSupe88's Avatar
The car I just bought had one mounted to the left of the steering wheel next to the window.
WikedOldsmoileSupe88 is offline
Cincinnati Rick
September 30th, 2021 05:13 PM
425HP409
October 27th, 2010 07:58 PM
alexrains
May 6th, 2010 12:06 PM
rocketrickshaw
July 20th, 2009 05:46 AM
todd66442
March 27th, 2009 05:38 PM
Quick Reply: Tachometer in your 50's Olds
