1 more wire
Old March 31st, 2024, 01:05 PM
Chuxter's Avatar
1 more wire
I have 1 connector coming out of my engine wiring harness that I have not figured out where it goes. I have looked through the diagram and still having a rough time. TIA
Chuxter is offline
Old March 31st, 2024, 01:29 PM
2blu442's Avatar
My guess is not factory. I say that because it looks like the brown wires are just jammed into the male connector. There's no female plastic piece the brown wires are attached to. But what year/model of car are you working on? If it is factory there should be something in the wiring schematic that reflects it.
Or am I seeing it backwards? Are either of the red wires connected or are they just in the background. Is it two brown wires in one male plug?
2blu442 is offline
Old March 31st, 2024, 01:47 PM
Chuxter's Avatar
Sorry the red wires are behind the image of the connector. They are not attached to it is a 1970 Cutlass Supreme. 2 Brown wires in a female plug located before the alternator wires and oil and temp sensors..
Chuxter is offline
Old March 31st, 2024, 02:10 PM
Chuxter's Avatar
Think I just figured it out. I have converted over to an internally regulated alternator, and this plug I believe went to the back of the old alternator. It has been many years since I have torn this down and didn't remember this. Does this sound correct?
Chuxter is offline
Old March 31st, 2024, 03:04 PM
That plug, as wired w/ two Brown wires, would not have attached to a 1970 internal VR ALT. The ALT would have been a Blue wire & a White wire in one plug attached to back of ALT.
Vintage Chief is offline
Old March 31st, 2024, 03:13 PM
2blu442's Avatar
I think the under hood light used one brown wire, and would be in that general area. But the two brown wires in one plug is not ringing a bell.
2blu442 is offline
Old March 31st, 2024, 03:15 PM
I'm suspicious the two Brown wires emanate from the wiring harness then plug into another connector w/ one wire leading to the under hood lamp the other wire leading to the tail light feed from the main lamp switch.
Old March 31st, 2024, 03:19 PM
Only one other location I can think of which I'll capture in a moment off the wiring diagram. But this is the one I'm suspicious you might be evaluating...
Old March 31st, 2024, 03:32 PM
Of course, a wiring diagram doesn't provide the length of any wire & I can't say the length of the wire emanating from the Main Lamp Switch - yet, it's a possibility two wires emanate from one wire. Additionally, please note both the LH & the RH side markers have a two Brown wire feeds as you trace the Brown wire branch. I suspect you're looking at a lighting wire.
Old March 31st, 2024, 05:50 PM
Gary
VC455's Avatar
That wire is the 12 V supply for the underhood light, which sits on the bottom of the hood above the master cylinder.
VC455 is offline
Old March 31st, 2024, 05:59 PM
Gary - I believe you're correct regarding the feed wire itself. But, as I recall, the actual Brown wire which connects to the underhood lamp has only one wire to the lamp itself doesn't it? It's been awhile since I re-wired my underhood lamp. I may be mistaken.
Old March 31st, 2024, 06:13 PM
Chuxter's Avatar
I am pretty sure this harness is from a later model that has the internally regulated alternator harness. So I think I won't worry about it unless I need it. LOL I am sure I bought it here so I'll look back and see what I bought. Thanks for the help.
Chuxter is offline
Old March 31st, 2024, 08:01 PM
Gary
VC455's Avatar
Norm, you are correct.
The double-brown wire in the Packard connector mates with a single-brown, which is the lead to the underhood light.
The first photo shows the connection between the double-brown and single-brown wires.
The next one shows the single-brown lead at the underhood light.
Connector is in the center of the picture nearer the right-hand side
The single brown from the connector powers the underhood light
VC455 is offline
Old April 1st, 2024, 05:15 AM
Originally Posted by VC455
Norm, you are correct. The double-brown wire in the Packard connector mates with a single-brown, which is the lead to the underhood light.
Phoenix8990
June 21st, 2021 04:29 AM
Puppy boy
April 14th, 2021 07:58 PM
oldsmoboogie
March 12th, 2021 02:55 PM
tnswt
October 11th, 2020 02:01 AM
Mark71
August 15th, 2016 06:30 AM
Quick Reply: 1 more wire
