12+volts no power to car anywhere 79 H/O
Old December 6th, 2023, 07:58 AM
leftlaneonly's Avatar
Could some one tell where to find the horn relay on a 1979 H/O and I will be checking the fusible link at the starter and know where that one is.
I walked into the garage and smelled something burning , uncovered the car and opened everything up disconnected the battery with a voltage of 11.87volts and let it sit. after an hour I charged the battery up to 12.5 witch did not take long and reconnected up to the car.
No lights or power anywhere and good voltage at the battery.
leftlaneonly is offline
Old December 6th, 2023, 08:02 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I don't know on a 79 but you should be able to follow the positive battery cable to it.
redoldsman is online now
Old December 6th, 2023, 08:08 AM
You most likely lost the fusible link that feed power to the cabin. I don't know exactly if it's at the starter or horn relay on your year model. I believe your horn relay is on the firewall. You'll need to figure out why it burned.
Another cause for complete loss of power could be at the bulkhead connector.
oldcutlass is online now
Old December 6th, 2023, 08:47 AM
Forgot to note that I washed the car over the weekend and may have been a little careless around the T-Tops.
That's the only thing I can think of that may have caused this as it was running fine then parked in the garage and covered.
Old December 6th, 2023, 08:51 AM
Where's 78cutlass4Speed.......Phil
Old December 6th, 2023, 10:08 AM
There are two fusible links. Both are at the main power stud on the starter. The horn relay is located in the convenience center panel next to the fuse box under the dash, unless you have the reminder package, in which case it is on a pigtail taped to the harness near the fuse box.
joe_padavano is offline
Old December 6th, 2023, 02:22 PM
While there are 2 fusible links, only one of them feeds the cabin.
Old December 6th, 2023, 03:30 PM
Lots of good advice
question if the cabin fuse would that include head lights and tail lights
Old December 6th, 2023, 03:39 PM
Originally Posted by leftlaneonly
Lots of good advice
Yes, it is the primary feed to the dashboard.
Old December 8th, 2023, 06:32 AM
The car will be lifted on Saturday , Volt meter in hand I will start digging into this.
Do they make a replacement cable or will I need to cobble one together?? What gage fuse willl I need
Old December 8th, 2023, 09:07 AM
Rodney
cdrod's Avatar
Replacing Fusible Link Wire
If the fusible link is burned, you will need to remove the bad link and crimp on a new fusible like wire. The general rule-of-thumb for sizing the fusible link is 4 wire numbers higher (smaller gauge) than the wire it's will be protecting; i.e. 14awg link will protect a 10awg wire, 16awg link to protect a 12awg wire, etc. Here is a link to 14awg Pico fusible link wire on Amazon.
Rodney
https://www.amazon.com/Pico-8125PT-Gauge-Fusible-Package/dp/B004BT6NZ2/ref=sr_1_fkmr0_1?crid=25A0H3BMW1UKO&keywords=Pico%238125PT+14+Gauge+%282.0+SQ+mm+x+6%27%29&qid=1702054821&sprefix=pico+8125pt+14+gauge+2.0+sq+mm+x+6%27+%2Caps%2C107&sr=8-1-fkmr0 https://www.amazon.com/Pico-8125PT-Gauge-Fusible-Package/dp/B004BT6NZ2/ref=sr_1_fkmr0_1?crid=25A0H3BMW1UKO&keywords=Pico%238125PT+14+Gauge+%282.0+SQ+mm+x+6%27%29&qid=1702054821&sprefix=pico+8125pt+14+gauge+2.0+sq+mm+x+6%27+%2Caps%2C107&sr=8-1-fkmr0
cdrod is offline
Old December 10th, 2023, 11:51 AM
A few shots. Positive battery cable shorted to the starter solenoid and took the two fuses-able links with it. So. New pos battery cable , net starter solenoid , and new fuse-able links. The last pic it fell on the floor what is it??
Old December 10th, 2023, 11:53 AM
Old December 10th, 2023, 12:15 PM
Rodney
https://www.amazon.com/Pico-8125PT-G...7&sr=8-1-fkmr0
As correctly noted by Rodney, it's in your best interest to purchase a fusible link (wire) since the wire itself & the insulation protecting the wire are NOT the same as a normal length of 14AWG wire. Best to buy a fusible link wire.
Vintage Chief is online now
Old December 10th, 2023, 02:02 PM
Obviously installed wrong. Also, get the correct length bolts for your starter.
Old December 10th, 2023, 02:11 PM
The round part that fell out is a spacer used on GM vehicles with side terminal batteries and two main cables going to the battery. This goes between the molded plastic ends of the battery cables to make contact. My 1999 truck has this. I don't think it came from the Olds originally.
Old December 11th, 2023, 04:58 AM
That's correct Joe fell off the battery.. I put it on the starter bolt on the bench so I would not loose it it was not on the starter bolt when I removed it.
Oldcutlass How can you tell it was installed wrong and is there a correct wire routing diagram out there
I will be replacing a lot of wires on this and new fuse-able wires . The fuse-able link has a 16 stamped on it it that the correct fuse-able wire to look for?
Old December 11th, 2023, 05:03 AM
Rodney
cdrod's Avatar
Following up on Norm's post; I didn't mention that the Pico fusible link wire has a flame-proof outer jacket that won't start a fire when it burns. 16awg is the correct size to protect a 12awg wire. You will only need about 6" of the Pico wire to do the job.
Rodney
cdrod is offline
Old December 11th, 2023, 12:18 PM
cjsdad's Avatar
He is basing that comment on the number of washers on that starter bolt. That may or may not have contributed to the wiring problems.
cjsdad is offline
Old December 11th, 2023, 02:19 PM
Yes, it looks like at least, the bolt with the washers is too long. The cable looks to have gotten pinched between solenoid and the block.
Old December 11th, 2023, 02:45 PM
Note this is not a stack of washers on a too-long starter bolt.
Fun71 is offline
Old December 11th, 2023, 03:27 PM
The positive battery cable To the starter I removed and will replace with new was black were they black or red from the factory
Old December 11th, 2023, 03:32 PM
cjsdad's Avatar
Eric has a good eye for starter bolts.
cjsdad is offline
I have not seen an Oldsmobile wiring diagram demonstrating anything other than red positive (+) power cables for any model year. You just watch, someone will post a 79 H/O w/ a black cable.
Old December 11th, 2023, 07:24 PM
Art S
Supernice88's Avatar
A good example of why I installed a battery disconnect switch. Luckily the fusible link did its' job.
Supernice88 is offline
Old December 12th, 2023, 04:40 AM
A battery disconnect switch is on my list of parts now. Thanks
I applied 12v to the two fuse-able link wires with a jump wire and all lights and power to the cabin worked.
after a little dance I removed the jump wire and will plan out the rewiring
Old December 12th, 2023, 06:04 AM
How does that help if it shorts while you're driving? It's far more likely that vibration from the engine while running will cause a problem. The right answer is ensure the cable is in good shape and routed correctly.
Old December 12th, 2023, 07:35 AM
BackInTheGame's Avatar
I'm surprised no one has mentioned this yet.
You need a 1979 Chassis Service Manual on your book shelf. Well, also for reference .
Here is one of several on eBay. Don't bother with re-prints or CDs, the quality sucks. Get an original.
You might (should?) also get the Fisher Body manual for your car. Again, buy original, not reprint.
Faxon Auto Literature.
BackInTheGame is offline
Old December 12th, 2023, 09:28 AM
Art S
But it might help from burning your garage and or house to the ground. He said, "I walked into the garage and smelled something burning".
Old December 30th, 2023, 10:49 AM
78Cutlass4Speed's Avatar
Dave, It sounds like you've gotten the problem resolved. Sorry, I just saw this post today. My computer died last month and I've been using my daughter's laptop. It wasn't unexpected since it was an old Toshiba model from 2006. Now the only issue is trying to retrieve all the photos I had stored on it including some of the cars and car shows I attended and especially some of my dog Ginger, who we had to put down in June after a sudden illness. If you have any questions or concerns about your car you can PM me or call me directly at my house.
Thanks,
Phil
78Cutlass4Speed is offline
Old January 5th, 2024, 04:33 AM
  #31
BlueCalais79's Avatar
Dave, how did this all go, did you get it resolved?
BlueCalais79 is offline
Old January 5th, 2024, 12:21 PM
  #32
Hey Blue
I had to make all the wires that go to the started and that took some time to get the correct wires for replacement. I cleaned up all the old connectors and attached them to the new wiring . also a new starter solenoid that did not fit but 2nd one same part number fit like a glove. I have everything ready for this weekend but first thing will be a sleeve for a broken oil dip stick tube that broke. with the starter out I can finally see this thing. and a oil change while it's up off the ground on 4 wheel ramps.
I am enjoying wrenching on the car
Old January 6th, 2024, 03:24 PM
  #33
Ok the wire with the small loop connector to one of the small connectors on the starter solinoid. The S post or the R 8 post please
Not the fuse link wires not the pos battery cable the others one
Old January 7th, 2024, 04:49 AM
  #34
The purple wire goes to the "S" (start) terminal. The "R" (resistor bypass) is not used with HEI.
Old January 8th, 2024, 05:37 AM
  #35
Thanks Joe_P
Old January 15th, 2024, 07:51 AM
  #36
I’m at the might as well point
Next up transmission pan gasket. Looks easy enough I have a new gasket will it need gasket sealer or put it on dry. What type transmission fluid. How much fluid please
Old January 15th, 2024, 07:53 AM
  #37
Dexron III.
Old January 15th, 2024, 08:22 AM
  #38
This is exactly why you need the Chassis Service Manual (CSM) where you will find the answer to each of your questions.
Old January 15th, 2024, 08:31 AM
  #39
I've had really good results with Lube Locker reusable gaskets. Install them dry. Be careful not to over-torque the bolts (and check the pan rail for flatness before reinstalling it - you can straighten it if needed). You'll want to change the filter while the pan is off.
https://www.lubelocker.com/products/...ssion-llt-g350
Old January 15th, 2024, 02:40 PM
  #40
Time for a short ride
Quick Reply: 12+volts no power to car anywhere 79 H/O
