1968 Cutlass S Headlights
Old August 16th, 2010, 09:10 AM
1968Cutlassfallbrook's Avatar
Hello,
I have noticed that my headlights seem to brighten and then dim for no reason. I have replaced the alternator with the factory style external regulator. I was wondering could there be a problem with the external regulator? Also hear a click noise when the lights change from bright to dim when it's on the low setting. thanks
1968Cutlassfallbrook is offline
Old August 16th, 2010, 09:33 AM
Oldsdruid
rocketraider's Avatar
First thing to check are the ground straps from headlight harness to the core support. Clean and tighten those connections will go a long way toward resolving this problem.
Then clean the h/l plugs and terminals. Corrosion causes more of this type problem than anything else.
Voltage regulator could cause this also, but my money goes on grounds and dirty connections.
rocketraider is offline
Teamcamber
November 1st, 2014 03:00 PM
Beeks69
May 8th, 2014 07:13 AM
Bobac455
March 23rd, 2011 03:50 AM
Cutlass.Don
September 17th, 2010 03:05 PM
DuezPaid
November 3rd, 2007 01:21 AM
Quick Reply: 1968 Cutlass S Headlights
