1968 turn signal flasher location
Old April 27th, 2015, 06:13 PM
ezheimers's Avatar
1968 442 - Where is the turn light flasher located? Thank You...
ezheimers is offline
Old April 27th, 2015, 08:55 PM
Please start your own thread with your question, rather than hijacking a dead three year old thread.
Welcome to ClassicOlds.
MDchanic is offline
Old April 28th, 2015, 06:21 AM
Welcome. I've moved your post to it's own thread. The turn signal flasher is on a wiring pigtail under the dash. The flasher clips into a clip screwed to the backside of the lower metal dash lip on to the left of the steering column. This is unfortunately not clearly spelled out in the Chassis Service manual.
joe_padavano is offline
Old April 28th, 2015, 07:21 AM
If you don't know what you're looking for (which would allow you to "let your fingers do the walking" behind the dash), you may need to find it the first time lying on your back with a flashlight in your teeth.
It will look something like this (but will be to the LEFT of the steering column, up under the dash, by the headlight switch):
MDchanic is offline
Old April 28th, 2015, 12:13 PM
allyolds68's Avatar
The search finction is your friend (although I will admit I cheated because I knew I posted this picture last year)
https://classicoldsmobile.com/forums...sh-wiring.html
allyolds68 is offline
Old April 28th, 2015, 12:22 PM
Better if the car isn't upside down.
MDchanic is offline
Old April 29th, 2015, 03:15 AM
Yellowstatue's Avatar
But you didn't show the secret location of the clip.
Yellowstatue is offline
costpenn
June 24th, 2015 10:38 PM
cargo442
September 11th, 2010 06:55 AM
DarrylJ
April 12th, 2009 04:37 AM
Flye
April 7th, 2009 02:34 AM
JPDPG
July 30th, 2007 03:28 PM
Quick Reply: 1968 turn signal flasher location
