1990 Custom Cruiser Wagon - Broken Heater
I am having trouble with the heater in my 1990 CC. It blows air, but it's cold air. Here's what I've done so far:
1. Checked coolant level, and it's normal.
2. Cranked heater on full blast and felt intake and output hoses on heater core, and both are hot, indicating clear flow.
3. Checked vacuum line to heater control valve, and it's securely connected.
4. Removed instrument panel and inspected the heater control. The cable is securely connected to the temperature lever at the heater control end, and securely connected at the flaps on the other end behind the glove compartment.
Anyhow, I've come to a dead end and I have no idea what to do next. Any ideas?
Also, I'm having a hell of a time with my instrument panel. Every time I remove it, little chunks of plastic break off. The plastic is really brittle and it always breaks before the metal clips pop out. It's getting to where the instrument panel sags and there's hardly anything holding it up. Does anyone else have trouble with this? It's really frustrating and the brittle plastic makes me not want to mess with anything.
My suggestion is to saw the head off of the heater control valve, and connect the rubber hose right to the remaining stump. You should always have heat then.
Then at the end of spring, you could replace the valve so it doesn't interfere with your AC.
Also, YES those blue plastic dash cages are steaming piles of doo doo.
I have sold 3 dashboards to people who broke theirs, or have had them broken permanently by some idiot stealing a stereo just this year alone.
This is the classic broken heater blend door. Assuming you have the manual HVAC and not the Tempmatic, the heater blend door is cable operated from the control head. It is very common for the plastic bellcrank that operates the door to break, resulting in only cold air. Remove the glove box insert and you can see the bellcrank on the firewall, above the HVAC box. Operate the cable while watching the bellcrank and it will become obvious as to the problem. This was so common a failure that Four Seasons used to sell a replacement bellcrank. Unfortunately, the part appears to have been discontinued - I tried to buy one earlier this year and it was no longer available.
Depending on where it's broken, it can be easy to repair. On my 86 Caprice wagon, the pin that the cable fit over had snapped off of the bellcrank. In that case it was very easy to simply drill a hole where the pin used to be and use a small machine screw and nut to replace the pin. That fix has worked fine for several years. If the bellcrank arm itself is broken, you'll need to glue it back together, adding some sort of reinforcing plate made from metal.
It's a manual control, so I don't know. I've also been told it could be a thermostat....
I've been told this might be the case, but I'm not sure exactly what I'm looking for. I have very little experience with car mechanics and this is the first thing I've tried to fix on my own. I removed the glove box and looked around. While flipping the temperature switch from hot to cold, I could see a metal arm moving back and forth behind the glove box. What exactly should I be looking for? And please excuse my ignorance; I have a lot to learn.
I apologize, I made a mistake. It is in fact a Tempmatic A/C unit. I just now noticed the logo on the heater control.
I've been experiencing similar heating issues as Griswold '90 in my 1990 Custom Cruiser. I'm in the process of pulling the vacuum relay and just want to ensure that I don't mess anything up. I removed the glove box and the vacuum port and lock stud from the relay ( see the attached photo). What is the correct/best method of removing the vacuum relay so that I can install the new one? Thanks!
Easiest way is to remove the whole programmer assembly from the HVAC case. I think there are FOUR screws holding it to the case, then the aspirator tube and bellcrank lever need to come off. Pull the programmer out and you can then easily get to the individual components. The vacuum relay snaps into the programmer.
nitrojunkie1029
Suspension & Handling
15
December 16th, 2014 02:21 PM
Griswold '90
February 6th, 2013 03:06 AM
waltchan
July 4th, 2007 10:36 AM
