3rd headlight plug?
3rd headlight plug?
Never noticed 'till now that I have an extra plug behind both driver and pass headlights. Can't see it in the chassis manual diagram. Related to nightwatch option?
I think you have a 1972 CS? Not sure if night watch was an option but sounds like a good guess. I don't own a 1972 CSM but generally separate wiring diagram(s) are provided in the back of the CSM in the accessory section, have you looked there?
I believe side marker/turn signal/parking lamps are light blue (left) & dark blue (right) (with a black wire for each). The green colored wire appears different than the light green color used for the headlamp dimmer switch so I suspect it is not associated with the headlamps; also, the black wire contains a white stripe which is also dissimilar to either the headlamps &/or the side marker/turn signal/parking lamps. Check in the back of the CSM in the accessories section for a separate wiring diagram?
Yes, 72 Cut Supreme. Posted laaaaate last night! Pic is in the body of the post; didn't load for you no1oldsfan? Brown and gray wires seen at the bottom, going south off the screen are the side marker wires. Sounds like a common harness used in 88/98s with provision for side markers....
Here is another pic with the side marker socket pulled up in view. My original pic I only pointed out the 2 wires going out of the shot to the side marker below. After cleaning overspray off the wires, I can see that the side marker wires are indeed light blue and brown. But the mystery socket/plug remains
DOH! We have a winner! Bumper is off for rechoming. I seriously was in the garage for waaaay too long yesterday! My apologies to all
No, the one that wasn't shown in the first photo, only the wires going to it, was for the side marker which I pulled into view for the second photo. The original plug in both was for the front bumper turn signal lights
