55 Olds dash lights and horn not working
Old March 2nd, 2015, 08:07 AM
Scharpp
scharpp's Avatar
Just got her up and going, it took a few times pulling and pushing the headlight switch to get headlamps working, but I have no dash lights, anyone dealt with this before? also I can make horn work at the relay but not from the horn ring on column, every things original, but sitting since 1969 Thanks
scharpp is offline
Old March 2nd, 2015, 08:18 AM
The horn is switched by a single wire seeking ground under your horn ring in the steering column, it may be corroded and not making good connection. I'm not 100% familiar with the 55 light switch, does it turn left to right as the later model cars with a rheostat on the back that controls the dim function? Also check your fuses and see if the lamp fuse is blown or corroded.
oldcutlass is offline
Old March 2nd, 2015, 10:46 AM
Scharpp
scharpp's Avatar
Thanks Eric, yes the light switch turns back and forth, figured someone has dealt with this and maybe it can just be cleaned or something, I will pull the horn ring and clean the contact, hope that works, man what a horn, it sounds like a train haha
scharpp is offline
Old March 2nd, 2015, 01:45 PM
Rocketowner's Avatar
Just use Spray contact cleaner on the rheostat of that dash light switch, and turn Back and forth several times ,and that will probably take care of the problem. Larry
Rocketowner is offline
Old March 3rd, 2015, 03:02 AM
Yellowstatue's Avatar
A '57 has a small fuse on the switch itself which powers the dash lights. Two amp or four fuse?
Yellowstatue is offline
Old March 5th, 2015, 10:08 AM
Ozzie's Avatar
As mentioned, there is a fuse on the light switch. It controls the instrument cluster lights, ash try lights, and the clock light. It is an SFE 2 amp. Also check the rheostat in the switch as suggested. Oxidation can form if it sits around without use, especially if the vehicle has "outside" storage.
The horn problem is also likely an oxidation problem. Clean the contact area on the steering wheel. If that doesn't fix it, trace the wire back from the relay and see where it will no longer trigger the relay.
Ozzie is offline
Old March 22nd, 2015, 05:29 PM
Scharpp
scharpp's Avatar
Hey guys thanks, got the horn fixed as per your help, I will pull the light switch as find that darn fuze, what the heck would they do that for? I checked everything else thats got to be it
scharpp is offline
Old March 22nd, 2015, 06:07 PM
twintracks's Avatar
Send me the clock. I'll get that going for you.
twintracks is offline
Old March 23rd, 2015, 02:41 AM
Frank Ignachuck
ignachuck's Avatar
X2 on that. Twintracks did a great job on my clock!
ignachuck is offline
Old April 7th, 2015, 09:50 AM
Scharpp
scharpp's Avatar
clock
Mine doesnt have a clock, I do have one in another dash but its to hard to change it out Thanks
scharpp is offline
Old April 7th, 2015, 10:28 AM
twintracks's Avatar
Yep, the speaker has to come out, otherwise, it's not too bad.
kansasculass
December 9th, 2011 06:11 AM
Mattia-SS
August 11th, 2011 01:26 PM
Scottem
September 28th, 2009 10:23 AM
cbogartjr
August 3rd, 2008 06:18 AM
<KEN>
September 22nd, 2004 08:39 PM
Quick Reply: 55 Olds dash lights and horn not working
