‘67 442 Unknown wire question
Old April 23rd, 2024, 07:20 PM
JesseOldsGuy's Avatar
Found this loose screw with two wires attached to it. It is on the driver side of the brake booster.
One wire goes here.
Does the screw go here?
The other wire goes into the car. I can’t get under the dash at this time to trace it.
JesseOldsGuy is offline
Old April 24th, 2024, 04:29 AM
Loaded68W34's Avatar
Someone removed the factory accessory circuit breaker on the firewall. This would provide power for power windows, power convertible top, or power seat. If you let that screw touch the firewall or any other bare metal surface of the car with the battery connected, it will likely start a fire as the black wire provides a direct path to the + battery terminal with no inline protection. You need to disconnect the battery and replace the original circuit breaker before doing anything else with the car. It looks like this:
Loaded68W34 is offline
Old April 24th, 2024, 05:14 AM
You need (require) two significant pieces of documentation:
1967 Oldsmobile Chassis Service Manual Original OEM
1967 cutlass 442 assembly manual
Vintage Chief is online now
Old April 24th, 2024, 11:30 AM
The screw was half wrapped in electric tape when I found it. I saw the hole and thought it should go there. Fortunately, the battery is out of the car as I am working on sheet metal corrosion under it. Thank you for the info. That picture shows a piece with what looks like two mounting holes and I have one open hole. I’ll look around that area, perhaps that doo-dad is there. Do both wires hook up to it?
Old April 24th, 2024, 11:31 AM
Thank you for the manuals recommendation.
Old April 24th, 2024, 12:04 PM
Yes, both wires hook to it. One wire goes on each terminal post. There should be two mounting holes on the firewall. The assembly manuals that chief suggested will show the specific location.
Old April 25th, 2024, 06:24 PM
Thank you!
Old April 30th, 2024, 07:23 PM
cjsdad's Avatar
This is what mine looks like. Dirty and original. The factory breaker has a large insulator on it to keep the wires isolated and protected from possible shorts. The red circle was for something else.
cjsdad is offline
Old May 1st, 2024, 06:50 PM
That helps, I was looking for the two holes today. I think I found a second one at an angle that would match what your photo shows. Thanks
centonze
December 13th, 2023 04:58 PM
JOHNNYOLDS442
May 29th, 2023 07:10 AM
Navyman53
August 19th, 2022 11:35 PM
2blu442
May 28th, 2020 06:58 AM
F85 330 ctls
May 29th, 2019 10:31 AM
Quick Reply: ‘67 442 Unknown wire question
