back up lights inop also need trailer....
Old September 14th, 2006, 02:07 PM
ztim's Avatar
Do back up lights have a seperate fuse? Everything else works just fine as far as the wiring goes.
Also, I was told a trailer wire plug is in the trunk somewhere so you don't have to do each wire individually.
ztim is offline
Old September 14th, 2006, 06:31 PM
TheCoroner's Avatar
Did you check your neutral safety switch?
TheCoroner is offline
Old September 14th, 2006, 06:39 PM
ztim's Avatar
Where and what is that?
ztim is offline
Old September 17th, 2006, 07:39 AM
TheCoroner's Avatar
Depending on the car..... but it should be on your steering column, about 4-6" from the firewall.
It'll most likely be mounted on the top of your column, so you'll have to look and feel around a little to find it.
I'd give it a continuity test after you disconnect it. This sends the signal to your reverse lights when you shift into reverse.
If you have a floor shift, it'll most likely be in a different location.
Old September 17th, 2006, 01:53 PM
ztim's Avatar
Ok. I found and it is right where you said it was on top of the steering column a few inches from the fire wall. I found one on the net that could be a replacement. It is a 5 prong switch.
When I was looking at it from underneath, I couldn't tell how to take it out or disconnect it or even remove it from the column. Would it pull apart from any direction? I did not see or feel any screws or hardware that I can tell.
ztim is offline
OldsCutlass70
May 2nd, 2013 09:29 AM
ao177snipe
January 5th, 2012 07:17 AM
Koby
October 1st, 2011 02:30 AM
nonhog
September 19th, 2011 10:58 AM
Z3d
November 18th, 2009 10:47 AM
Quick Reply: back up lights inop also need trailer....
