car wont start. no dummy light, radio, anything
Old September 8th, 2010, 09:37 PM
onlythego
tnelson's Avatar
ok guys, i parked my 77 grand grix(factory olds 350 rocket) outside for the weekend came out two days later and it wont start. when i tried to jump it the dash lights turned on only with the cables on but i wouldnt turn over. i heard a clicking and assumed it could be a starter. well im stupid and put it in for nothing. i dont wanna make another dumb move so please help, bad battery?, alternator?, fuse?, wiring?
tnelson is offline
Old September 9th, 2010, 05:19 AM
MN71W30's Avatar
Clean the battery connections. Your solenoid is clicking from lack of battery power. Did you leave a light on over night? If so your battery is really dead and will need a good charge. Leave it on a 15 amp or more charger for a hour or two and try it again. You may have lost a cell in your battery and it could need replacing. A battery from another car will start it faster if you need to get on the road. Are you in the Twin city area?
MN71W30 is offline
Old September 9th, 2010, 05:47 AM
onlythego
tnelson's Avatar
thanks for the advice mn71w30. yes, im in white bear lake and im kind of thinking its the battery probably being too dead to jump.
tnelson is offline
Old September 9th, 2010, 06:22 AM
Lady72nRob71's Avatar
This can easily happen. Most jumper cables cannot deliver the high current needed to start a car if the battery is completely dead - the wires are not thick enough and they are too long. They are more correctly called "booster cables".
Try to charge overnight. If unsuccessful, the battery is prolly gone.
Lady72nRob71 is offline
Old September 9th, 2010, 06:49 AM
NôôB
sicky olds's Avatar
or take it to your nearest auto zone or what not and they can do a quick charge on it in an hour for free. and then they can test it for you also. that swhat i usually do
sicky olds is offline
Old September 9th, 2010, 07:22 AM
Good idea also. They check initial voltage, load test it and check the recovery rate. Fast and accurate.
Old September 9th, 2010, 08:01 AM
MN71W30's Avatar
I'm only a couple miles away if you need a hand let me know.
Dave
MN71W30 is offline
Old September 9th, 2010, 01:33 PM
greenslade's Avatar
When charging a totaly dead battery you may have to hook a second battery to it,to get it to take a charge.don't forget to check the ground connections
greenslade is offline
Old September 10th, 2010, 05:42 AM
Good point - those automatic-type chargers may require this, as they may sense full when really not.
Arrowstorm
August 9th, 2015 04:27 AM
bigzoman
January 27th, 2014 07:04 AM
oldsmoboogie
September 22nd, 2012 10:27 AM
nj_cutlass72
September 4th, 2012 08:39 PM
76Supreme350
July 19th, 2010 05:50 PM
Quick Reply: car wont start. no dummy light, radio, anything
