Cigarette ligther
Old June 29th, 2010, 01:55 PM
tim72's Avatar
Cigarette ligther
I bought a after market cigarette lighter from O reillys and found the housing did not fit because it had a longer lenght then the original. I ended up buying the correct one from Year one for $25. In the wiring diagram I only see 1 big orange wire connecting to the back of the cigarette lighter with no ground attachment. Is this correct? The reason I ask is the one from O'reilys had an attachment for a ground. I kept blowing fuses so I figured I had better start from scratch with the correct lighter. Wonder why the after market didn't work?
tim72 is offline
Old June 29th, 2010, 02:30 PM
I don't know anything about the aftermarket version, but the stock lighter (and all other dashboard components) ground through a stamped sheet metal ground plate on the backside of the plastic dash. The lighter housing clamps onto this ground plate when you screw the two parts of the housing together. That's why only a single power wire is required.
joe_padavano is offline
Old June 29th, 2010, 05:56 PM
tim72's Avatar
That answers the question. Thanks Joe
tim72 is offline
Old June 30th, 2010, 05:30 AM
Lady72nRob71's Avatar
I was wondering if the generic aftermarket lighter parts would interchange - now i know!
Lady72nRob71 is offline
Old July 18th, 2010, 12:16 PM
hamm36's Avatar
I know this is a simi old post.
Is the back of you cig-lighter a blade contact, or a round contact????
Mine is a blade, but the wire I have for it is for a round contact. I am kind of waiting to see what I should do.
hamm36 is offline
Beob
March 5th, 2011 01:45 PM
Phil Glass
October 25th, 2010 11:20 AM
tim72
August 5th, 2010 07:51 AM
Bunser
May 24th, 2010 05:47 PM
tim72
April 27th, 2010 05:41 AM
Quick Reply: Cigarette ligther
