Coil specifications
Old September 10th, 2008, 09:26 AM
scott_442's Avatar
Coil specifications
Anybody have the resistance numbers, both primary and secondary, for a 1972 350? Also, how far out of spec is replacement warranted? Thanks.
scott_442 is offline
Old September 10th, 2008, 02:15 PM
I doubt there is a measurement available for that. I am sure the engineers knew what it was, but a coil either works or it doesn't. Take the coil wire off and ground it to the frame or engine, then have a buddy crank the engine over. IF you see your coil wire sparking then it is good. If it doesn't spark then your coil might be bad.
Olds64 is online now
Old September 10th, 2008, 04:53 PM
Registered
Bluevista's Avatar
The general specs in the chassis electrical section in my '71 service manual shows primary resistance for a V-8 coil at 75 degrees is 1.77 to 2.05 Ohms. The secondary resistance is .6500 to 9500 Ohms.
Not sure if they would be the same for yours or not.
Allan
Bluevista is offline
Old September 10th, 2008, 10:59 PM
Just the facts...
BILL DEMMER's Avatar
a resistance test isn't that reliable of an indicator. sure, it will show a hard-short, but since we're talking about something that is essentially a step-up transformer, the only way to test for breakdown would be a high-voltage probe. those aren't very common these days. if you're in doubt about your coil-just replace it.
bill
BILL DEMMER is offline
2blu442
March 5th, 2010 02:27 PM
Prsabordo
March 3rd, 2010 02:38 PM
oldsmerc
September 23rd, 2009 10:09 PM
FATRATMATT
April 11th, 2009 05:06 AM
442 Guatemala
February 19th, 2009 07:20 PM
Quick Reply: Coil specifications
