Dimming Aftermarket gauges
Old September 25th, 2012, 06:36 AM
mdd71's Avatar
I have installed an oil and water temp. gauge for my 455 in a 74 Cutlass. I am now trying to figure out which wire to connect to get the bulbs to dim. I am guessing the headlight switch dimmer wire. But which is the dimmer wire. I am guessing the grey wire. Any thoughts.
mdd71 is offline
Old September 25th, 2012, 07:43 AM
You can splice into any dash wiring that dims. I like mine full bright all the time, as they are below the dash.
oldcutlass is offline
Old September 25th, 2012, 08:34 AM
RandyS's Avatar
The wire is gray on a 66. You can splice in to any wire that goes to a panel light.
RandyS is offline
Old September 25th, 2012, 09:28 AM
805cut's Avatar
I just got done wiring my lights and gauges yesterday, the wire i used for my gauge lighting was gray and they all dim. 70 cutlass
805cut is offline
Old September 26th, 2012, 07:23 AM
mdd71's Avatar
I do remember it being the gray wire but that was 25 years ago.
Thanks.
mdd71 is offline
63super88
August 17th, 2013 12:47 PM
raw442
May 14th, 2013 05:56 PM
raatj011
July 31st, 2012 06:27 AM
citcapp
December 14th, 2009 11:10 AM
skibone
April 15th, 2004 03:13 AM
Quick Reply: Dimming Aftermarket gauges
