Heater Control Valve Elec. terminal?
Old April 7th, 2012, 12:01 PM
zodiacblueS's Avatar
Any idea where I can find the screw-in electrical terminal for a heater control valve? I think I read it can be just be grounded out, as it only shuts off the HW flow during air conditioning. Screws into the end, and has a spade type connector that mates with the one draped over the valve in the pictures. Thanks in advance.
zodiacblueS is offline
Old April 7th, 2012, 01:06 PM
The one that looks like this?
You're looking for GM part #6490081 (if it's the one-terminal switch).
It is sold by Airtex through the usual outlets as Airtex #1T1040.
You can get it for $85, $50, or $36, your choice, or you can just ground that wire to leave "Low Fan" permanently enabled and be done with it.
File Type: jpeg
MDchanic is offline
Old April 7th, 2012, 01:11 PM
Excellent, Thanks Doc.
Can you tell me what the impact to my heating,cooling system is if I do just ground it out?
Old April 7th, 2012, 01:33 PM
Grounded: You have all fan speeds, Low through High, all the time.
Open: You have all fan speeds when the engine coolant temperature is above 40°F, below that you have no Low speed.
MDchanic is offline
Old April 7th, 2012, 02:38 PM
Thanks for the info. I love this forum!
jensenracing77
March 19th, 2014 04:08 PM
oldspackrat
November 23rd, 2011 08:19 AM
Mister
May 13th, 2011 03:53 PM
blue72regency
December 12th, 2007 01:12 PM
bjtstarfire
December 15th, 2006 10:14 AM
Quick Reply: Heater Control Valve Elec. terminal?
